Old 09-08-2012, 07:38 PM   #1
Stay Classy San Diego
Merry's Avatar
Question About the Outside Shower
We have the Solera 24M. It has the outside shower with the coiled hose and nozzle end. It has a quick connect end on it, but it doesn't turn on when connected. Is there a valve inside somewhere to turn it on? Maybe a turn on/off to winterize it that's in the off position? Or does the fresh water tank need to be full to use it? We were on city water which should have worked? It has the Arctic Package if that makes a difference.
Thanks for any help!
2012 Solera MS
NO AGNDA
Merry is offline   Reply With Quote
Old 09-08-2012, 08:04 PM   #2
2012 Solera
Make sure you have the quick disconnect completely plugged in - it is VERY tight and hard to fully connect. If plugged in properly - make sure the nozzle is open.
JLeising is online now   Reply With Quote
Old 09-08-2012, 08:25 PM   #3
Merry's Avatar
As far as we can tell, it was completely plugged in. Husband doesn't want to force it any further - he doesn't like the pressure that puts on the plastic line. Who knows where that goes to? Our bathroom is in the back and we looked under the sink and shower but couldn't see where it joins to the water line. We don't want the 'outside shower' to suddenly be under the unit due to a broken pipe! Thanks for your reply!
2012 Solera MS
NO AGNDA
Old 09-08-2012, 09:52 PM   #4
2012 Solera
I find I can more easily get it on with the water turned off, pressure released (open an inside faucet after turning off the water), and the metal release ring pulled back to the "release" position. You are pushing against the water pressure when you push the hose quick disconnect in; the release ring helps relieve pressure from the locks that hold the disconnect "in" when it is engaged. Good Luck!
Old 09-08-2012, 09:56 PM   #5
Merry's Avatar
Thanks I'll try that tomorrow
2012 Solera MS
NO AGNDA
Old 09-10-2012, 07:18 PM   #6
Hi,
Are you sure it is an outside shower and not a rinse hose for the.grey and black water. Also, do you know if the water supplied from the hot or cold side. Cold might not be to comfortable.
2012WhiteSolera is offline   Reply With Quote
Old 09-10-2012, 08:10 PM   #7
papap's Avatar
Cold
On mine it is only a cold water faucet.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 09-10-2012, 08:15 PM   #8
Merry's Avatar
I am assuming it is cold only as there are no faucets, so I believe it's just for rinsing off the hose. Or gloves. Or boots. Or whatever!
I didn't get a chance to work on it today, but I will tomorrow. I just don't want to force it but will try it tomorrow with the water turned off as JLeising suggested
2012 Solera MS
NO AGNDA
