Old 08-14-2013, 03:41 PM   #1
Question for Battery Gurus
My battery reads 12.6 volts with nothing turned on. Same thing if I switch the battery switch off. If I turn on lights the voltage drops to the point that it read 12.2v with 8 lights on.
I know that those eight lights are drawing a fair amount of current, but what would explain the voltage drop as measured at the battery?
In theory, with sufficient current capacity the voltage at the source should remain constant.
Does that mean that the open circuit voltage is a false reading and that the true state of charge is indicated by the voltage when under load?
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 08-14-2013, 03:43 PM   #2
avolnek's Avatar
a battery will almost always read a higher un loaded voltage vs a loaded voltage... just normal battery life... the load will always draw some of the voltage down...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-14-2013, 04:00 PM   #3
TURBS's Avatar
I hope your camper isn't plugged when you took the readings.
Because it should read higher voltage.
T
Old 08-14-2013, 04:04 PM   #4
Right. 13.7 when plugged in.
2011 Solera 235S
Freightliner Badge
Old 08-14-2013, 05:02 PM   #5
Great Horned Owl's Avatar
Every battery has a certain amount of internal resistance. You can think of your battery as being an ideal voltage source with a small (well under one ohm) resistor in series. As you draw current, the voltage drop across the internal resistance is what you are loosing.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 08-14-2013, 05:08 PM   #6
I guess that makes sense.
8 lights = approximately 12 amps, 0.4 drop = .03333 ohms internal resistance.
I imagine that resistance goes up as the battery discharges, compounding the problem!
2011 Solera 235S
Freightliner Badge
Old 08-14-2013, 08:11 PM   #7
I found and posted in a previous thread taking battery stuff. Try that for starters. Its actually pretty informative.
2012WhiteSolera is offline   Reply With Quote
battery
