Old 11-16-2015, 01:23 PM   #11
Smile Exide Batteries
Sounds like a good way to get info on the batteries and a question for you all. We have a 2014 sunseeker 2650 with two batteries under the step. They are sealed type with a green indicator light and they have never been a problem. My question is, do the tops come off to check the distilled water level or not? I have been on the Exide web site and haven't found anything to say that you can add water.
When our camping season is over, I take the batteries out and into the basement for the storage season and keep them charged.
427creston is offline   Reply With Quote
Old 11-16-2015, 02:04 PM   #12
camaraderie's Avatar
Conversion from RC to 20hr. amp rating is approximately RC divided by 2 +16... so the exide 160 group 27 would be 80+16 or 96amp hours which is about right for a Group27 deep cycle. The 140amp group 24 would then be 70+16 or 86 which strikes me as quite high. I'd suggest using 75 amp hours with a group 24.
Note:
"No accurate RC to Ah conversion exists but the most common formula is RC divided by 2 plus 16. A short method is dividing RC by 1.9. Differences in discharge current produce some inaccuracies." BU-904: How to Measure Capacity – Battery University
@427creston
The battery with the green inspection port window is a sealed lead acid no maintenance dual purpose battery. It is NOT a deep cycle or refillable. It holds more water internally and has an internal valving system designed to return MOST of the boiled off vapor to the "well"...at the expense of battery plate size (life/capacity) They are not a good choice for RV's and should not be left on chargers full time. When you remove them from the coach, suggest you fully charge them then stop charging and check again on state of charge in 2 months.
Expected life would be 2-3 years...more or less depending on how much you cycle them.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 11-16-2015, 02:58 PM   #13
Thumbs up Battery life
Thanks Cam , I thought that would be the answer to my question ,so thanks again for that , another question what would be the best type? that will fit in the space of a Sunseeker step, I have used deep cycle in other motor homes but they have had more height .
Old 11-16-2015, 03:00 PM   #14
Karen, Pete & Chloe Kat
sanpedroflyer's Avatar
Sealed Coach Batteries
No, the tops DO NOT come off! Sealed batteries have no access to check water level or electrolite charge. The only thing you can do is check the green looking light if it has one.
For what it is worth, I have done a lot of research and talked to several experts. Consensus is that "Flooded Cell Lead" batteries are better than "Sealed" batteries because you can get an accurate reading of the batter charge level by checking the electrolyte using a hydrmeter.
sanpedroflyer
sanpedroflyer is offline   Reply With Quote
Old 11-16-2015, 03:06 PM   #15
Motorhome Batteries
Originally Posted by Mike968 View Post
I was under the impression the dealer installs the batteries on new units shipped from FR. Is that incorrect?
I think the RV Coach batteries are installed at the factory. But I will call my dealer and ask.
Old 11-16-2015, 04:33 PM   #16
Batteries
Our 2014 batteries have a 1.5" x 2" label marked D27DC-160.
PenJoe is offline   Reply With Quote
Old 11-16-2015, 05:10 PM   #17
dukeboone's Avatar
Originally Posted by Joshua Cavitt View Post
This may be a conservative answer but Via our electrical engineer our batteries are group 27 and 100 Amps not 160.
Thanks for the info Josh. I didn't intend to convey that Worldwide Batteries had said the Amp Hour rating was 160A but rather the Reserve Capacity was 160A. I know that sometimes information gets mis-translated in text, so just thought I would clarify. Personally I used 94AH/battery as a calculation from the reserve capacity for a total of 188AH. I subsequently programmed my solar controller to consider the batteries to have a total of 180AH (the settings only allow for 10A increments) to be conservative.
Just as camaraderie pointed out Reserve Capacity and Amp Hours cannot be confused as they are different methods of measuring a battery's performance and capacity.
Note:
"No accurate RC to Ah conversion exists but the most common formula is RC divided by 2 plus 16. A short method is dividing RC by 1.9. Differences in discharge current produce some inaccuracies." BU-904: How to Measure Capacity – Battery University[B]
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 11-16-2015, 05:12 PM   #18
tahoe1840's Avatar
snapedroflyer, according to my dealer the batteries for our 2015 Flaggstaff 8528RKWS 5th wheel were shipped with the coach but not installed. The dealer installed them. The shipping battery went with the shipper. The installed batteries when we took delivery were group 24 Exide Marine/RV, as near as I could research they were 100 AH. Both batteries failed in the second year. I went through extensive research on what you are going through and settled on a Renogy 100 watt suitcase solar system. We did this for versatility, that being enabling us to move the panels easily into sun. This system also has a controller built onto it. We found that there are millions of opinions on battery types. Most feel AGM batteries are good but if one is diligent with maintaining their batteries a flooded battery is more cost effective in the long run. We decided on Trojan 6 volt gold cart batteries wired in series. Works amazingly well and 3 to 4 times better then the 2 12 volt Excide batteries. If you need more info please PM me.
tahoe1840 is offline   Reply With Quote
Old 11-16-2015, 05:14 PM   #19
tahoe1840's Avatar
That's "golf" cart... :-)
Old 11-16-2015, 05:25 PM   #20
Well...the batteries under your steps are likely either Group 27 or Group 24 size. If you cant see a 24 or 27 printed on the battery the next choice is to measure your EXISTING batteries to determine what they are and while you are there...see how much extra room in height, width or depth you may have available. The approximate (within 1/4") dimensions of the three most popular sizes of 12V RV deep cycle batteries are:
Group 24...10.75x6.75x9.4"
Group 27...12.5x6.75x9.4"
Group31...13x 6.75 x9.4"
...as you can see... the height should not be a problem and only the length varies. Squeeze in the highest group number deep cycle that will fit in your space...typically...75/90-95/100-105 amp hours respectively in these sizes per battery.
The other choice is a pair of 6V deep cycle batteries wired in series to give you a "single"big 12V battery. Dimensions on these are:
10.3x7.2x10.8" so you need more height & a little more width for these.
If you boondock a lot...a premium deep cycle battery will pay for itself if maintained...Here's the whole Trojan line with complete specs so you can pick what fits for you if you go the premium route.
http://www.trojanbattery.com/pdf/TRJ...SpecGuide.pdfn
If you don't boondock much, a conventional deep cycle will suit fine....I like the Deka brand myself (East Penn MFR.) and they make for a lot of other labels...almost always you will see a model number starting with DP or DC and then the group size if it is a Deka. i.e. DC27 = deep cycle group 27
...avoid the DP dual purpose designation...and with any other batteries if you can't get a 20 hour amp spec...keep walking. Reserve Capacity, CCa amps and any reference on the label to starting is NOT a true deep cycle battery.
Hope this helps.
________
Cam
solera, battery
