Old 10-19-2013, 10:23 PM   #1
Question - Leveling Solera with Lynx Blocks
When using Lynx Blocks to level the Solera, do we need to use blocks under both tires of the rear duals? And if not, do we put the blocks under the inside tire, or the outside tire? Thanks!
Larry, Paula & Bailey the Adorable Red Toy Poodle
aspengirl is offline   Reply With Quote
Old 10-20-2013, 05:45 AM   #2
Always support both inner and outer tires equally. The suspension is designed to support the weight of the vehicle on two tires. Failure to do that can result in stress on parts of the suspension that it is not designed to stand.
We carry 3 sets of Lynx blocks and have rarely used the third set but always support inner and outer tires equally.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 10-20-2013, 09:43 AM   #3
Originally Posted by RvBill3 View Post
Always support both inner and outer tires equally. The suspension is designed to support the weight of the vehicle on two tires. Failure to do that can result in stress on parts of the suspension that it is not designed to stand. We carry 3 sets of Lynx blocks and have rarely used the third set but always support inner and outer tires equally.
Thank you for the helpful information!
Old 10-20-2013, 09:44 AM   #4
hkreck's Avatar
X2 on what RvBill3 is saying, I have about 4 bags of these blocks just in case.
Henry & Tena
hkreck is offline   Reply With Quote
Old 10-21-2013, 09:55 PM   #5
Thank you!!
leveling, solera, lock
