Old 09-28-2014, 03:16 PM   #1
Loefflerh's Avatar
Radio Antenna
Did somebody replace the radio roof antenna on a Solera 24R -its a 2013.
Mine came apart at the base - bits and pieces of a kind of a washer came out at the base, I guess over torqued during installation.
I do not know whether the antenna cable is screwed on at the base or permamently attached to it...if it is attached I have a problem. There must be an extension cable going to the dash - but that connections is hidden behind the fridge - or does anybody know where to find it?
Anybody (BC?) knows the manufacturer of the antenna?
Loefflerh is offline   Reply With Quote
Old 09-29-2014, 10:28 AM   #2
GM
bclemens's Avatar
I posted something on this a while back. One guy had one where the sealant was twisted...had the same question. I answered it then...but don't remember what my answer was. I think I even took a picture of the antenna. Let me do some searching.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-29-2014, 10:30 AM   #3
GM
bclemens's Avatar
Found it.
Roof Radio Antenna Seal
Not sure if that helps.
Old 09-29-2014, 12:11 PM   #4
Loefflerh's Avatar
Thanks for the reply! But that did not help much...
I need to find out whether the antenna cable unscrews from the antenna itself (accessible behind the microwave) which I don't believe,
or where the connection of the antenna cable and extension (going to the dash) is hidden. Is there any way to find out , maybe calling the factory?????Please??
Old 09-29-2014, 12:24 PM   #5
Iwannacamp's Avatar
I just took mine off...low trees...stupid idea... I put an internal flexible antenna from ebay for like $5. Works for me...
Old 09-29-2014, 02:45 PM   #6
GM
bclemens's Avatar
Here is the antenna. It pushes on, with a screw on nut to keep it in place. The splice is typically made in the fridge or microwave cabinet depending on length.
Name:	2014-09-29 15.20.02.jpg
ID:	63765   Click image for larger version
Name:	2014-09-29 15.20.28.jpg
Old 09-29-2014, 04:50 PM   #7
Loefflerh's Avatar
that is great - thank you very much!
That means the antanna cable is screwed on at the base. Those are good news - because the "splice" is hidden behind the fridge....so now its an easy replacement! Would you happen to know the manufacturer of the antenna?
Old 09-30-2014, 10:44 AM   #8
GM
bclemens's Avatar
box had no markings. email into purchasing.
antenna, radio
