Old 12-12-2013, 12:38 PM   #11
bubbles's Avatar
Those are 2 audio (red/white) and 1 composite video cable (yellow one). Do you have audio and no picture? do you have picture and no audio? if you have neither then the harness is either open or the connectors are at fault. Even without video you should get audio if all is connected correctly. I believe.
Old 12-12-2013, 04:34 PM   #12
Make sure you have set the TV to the correct input. There is an AV1 and AV2 input. It could be that the cable is plugged into the wrong input.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 12-12-2013, 04:53 PM   #13
Mikegjax's Avatar
Thanks all for your replies. I thought I had found the problem with one of the ends. It had been cut so I replaced that and no help.
I can't run new wires as they are stuck firmly in the wall. Next step is to swap audio with video cables. I will do that in the next day or so. Like I mentioned earlier, it works fine when an external cable is connected directly from the player to the TV. I will let you know the outcome. Good news is that while I had the radio out I installed the SAT tuner and antenna.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 12-12-2013, 04:57 PM   #14
an ohmeter will tell you which one is bad
Rockwood 8282 WS
2012 F-250 6.2
farfetched is offline   Reply With Quote
Old 12-12-2013, 05:14 PM   #15
Mikegjax's Avatar
I will do a continuity check on them when I get the radio out again. I did not do one the last time as I thought the bad end was the problem. Shame on me!
2014 Solera 24R
USN Retired
Old 12-12-2013, 05:16 PM   #16
Ford Idaho's Avatar
You could have a screw or a staple thru the wire.
Old 12-13-2013, 06:45 AM   #17
Mikegjax's Avatar
I'm leaning toward the screw or staple idea.
2014 Solera 24R
USN Retired
Old 12-13-2013, 07:35 AM   #18
kerrlakelover's Avatar
Performing the continuity check would tell you almost for sure in the fact if the wires were shorted or broken by a screw or staple.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 12-14-2013, 11:33 AM   #19
Mikegjax's Avatar
Switched one of the audio cables with the video and all is well. You would think the system would have been tested before leaving the factory.
2014 Solera 24R
USN Retired
Old 12-14-2013, 11:42 AM   #20
Ford Idaho's Avatar
