Old 11-02-2015, 11:32 AM   #1
Rear Camera "No Signal" 2400R MBS
All of the sudden .. during a trip the RVS-770619N system said NO SIGNAL only on the rear view camera. The 2 side cameras still work. Where is the multiplexer even located in the Solera/Sunseeker MBS? I assume it must be either a loose connection or a bad camera. But how do you start to figure it out?
oregonct is offline   Reply With Quote
Old 11-02-2015, 11:51 AM   #2
Mikegjax's Avatar
From what was previously posted, it is near the steering column.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-02-2015, 12:42 PM   #3
Thanks. My search criteria must have been too narrow.
Old 11-02-2015, 03:42 PM   #4
Pod2Vibe's Avatar
Below headlight switch, behind gray panel.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 11-03-2015, 01:16 PM   #5
Curious about your temperature. My rear camera quits working around 50 degrees. When it warms up in the cab it comes back on.
SSmbs is offline   Reply With Quote
Old 11-03-2015, 01:26 PM   #6
Normal temperatures .... 70-80 degrees. Last night I fiddled with the wires under the dash and the camera started to work again so it looks like I have a loose wire.
