Old 07-21-2013, 09:30 PM   #1
Rear LED lights stay on all the time
The rear LED lights are on constantly on even when the coach is completely shut down. It is only the two bulbs on the inside on the rear lights. This is a new problem that I just noticed tonight. Solera is new with only 5000 miles. Anyone had this issue or know of secret switch.
steeproad is offline   Reply With Quote
Old 07-22-2013, 06:11 AM   #2
lindy's Avatar
Could be a stuck brake light switch?
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-22-2013, 06:28 AM   #3
Herk7769's Avatar
Ditto on the stuck brake switch.
HAM CALLSIGN - KC3FFW
Old 07-24-2013, 03:42 PM   #4
I don't think the brake lights should come on if the chassis key switch is off, regardless of the brake switch.
I'm thinking there may be some kind of relay board in the coach that controls the rear lights and it is the culprit. Just a hunch really but I don't know of any modern vehicle that will light the brake lights when the vehicle is not turned on.
Ogsarg is offline   Reply With Quote
Old 07-25-2013, 10:12 PM   #5
Well I just went out and stepped on the brakes with the key off (in fact the key was in my hand) of my 2011 Ford F350 and the brake lights came on. I know that our 2011 Toyota Highlander brake lights come on no matter if the key is on or off.
I would sure look at the brake switch first, don't' make it any more complicated than it needs to be. .Check the simplest thing first before checking on relays and everything else
butch50 is offline   Reply With Quote
Old 07-26-2013, 12:43 AM   #6
Try checking the voltage on the trailer hitch (connector) first. If no brake light voltage is present at the hitch then you probably have a control board problem. If constant voltage at the hitch then start checking at the brake light switch.
cousin01 is offline   Reply With Quote
