Old 06-10-2016, 06:47 PM   #1
Robert Mayberry
Rear View Safety Camera
Hello,
My 2011 S has the Rear View Safety camera. Does anyone know where the control unit is located?
Thank you
Robert Mayberry
San Francisco
robertmayberry is offline   Reply With Quote
Old 06-10-2016, 07:44 PM   #2
Mikegjax's Avatar
Should be near the steering column.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-11-2016, 07:40 AM   #3
It's located behind the fascia, below and to the left of the steering column, on my 2015 R.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 06-12-2016, 06:25 PM   #4
Robert Mayberry
Now i am stumped. Looked under the dash left and right of steering column. Nothing there.
Any other ideas?
Old 06-12-2016, 09:51 PM   #5
Did you look behind the plastic above the hood release latch? That's against the left side of the cab, to the left of your feet...
2015 Solera 24R
Old 06-14-2016, 02:52 PM   #6
Originally Posted by robertmayberry View Post
Hello,
Thank you
Robert Mayberry
San Francisco
Hi Robert!
Have you checked under driver's seat? It's usually near the fuse box, so that is a little odd. What kind of camera is it?
Curt
RV_Fan44 is offline   Reply With Quote
Old 06-15-2016, 08:54 PM   #7
It's under the dash to the left of the driver. Mine was just kinda crammed up there.
RJBeauchene is offline   Reply With Quote
Old 06-18-2016, 12:18 PM   #8
Robert Mayberry
Never did find it. Apparently there is none. Took it to my mechanic and they replaced the camera which had failed. He said there was no box.
The bill was $950. $350 for camera. Also included replacing the hot air furnace duct under the refrigerator. The factory had cut it too short so they didn't bother to hook it to the furnace.
Old 06-24-2016, 11:44 AM   #9
HVrunner's Avatar
The multiplexer on my 2015 MBS 24R is behind a small panel above the fuse box just to the left of the driver's left knee. I had to remove a screw on the bottom of the panel. The multiplexer was secured with a wire tie.
2015 Forester 2401R MBS
HVrunner is offline   Reply With Quote
safety
