Old 06-02-2014, 01:04 PM   #1
Northern Most Member ?
Toolman Taylor's Avatar
Remote camping extended stay idea
Just an idea.....
To extend potable water use while camping in remote areas how about drafting from a portable water jug using the winterizeing hose.
You could just turn the water valve to winterize and draft from maybe a 5 gal water jug or other portable source.
If you had a tow vehicle you could haul water from sources that you wouldn't / couldn't drive your Solera to.
Has anybody tried this? Any drawbacks?
Tim + Denise Taylor
Denali Park Alaska
2013 Solera 24R
Toolman Taylor is offline   Reply With Quote
Old 06-02-2014, 03:56 PM   #2
2012 Solera 24S
With this simple mod:
Solera Fresh Tank Fill Modification
You can completely fill your fresh water tank from any size portable source.
Nats is offline   Reply With Quote
Old 06-02-2014, 04:06 PM   #3
Thanks Nats
Not sure where I would make these connections on a 24R but I will snoop around and see if I can find the lines.
Great idea!
Tim + Denise Taylor
Denali Park Alaska
2013 Solera 24R
Old 06-02-2014, 04:16 PM   #4
Looking at your schematic again wouldn't you also need a closed valve on the cold water line just after the new fill junction to insure the water your pumping goes to the tank?
Have you tried just pumping water as needed from an external tank using the glycol hose seniero?
Tim + Denise Taylor
Denali Park Alaska
2013 Solera 24R
Old 06-02-2014, 05:43 PM   #5
2012 Solera 24S
No, the third port in the 3-way winterize valve (normal port) is blocked when the valve is switched to winterize. It has to flow into the tank as long as all of the remaining point of use valves in the Solera are closed.
I've tried it, it works.
camping
