Old 06-28-2016, 11:44 AM   #11
Pod2Vibe's Avatar
I would say it weighs in at about 25 lbs or so. Which in the MBS's case does help.
Best thing ever did was remove it as it really opens up the bedroom and makes it easy to walk around the bed in the 24R.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 06-28-2016, 11:54 AM   #12
Thats exactly what I was thinking. I really do not see ever closing the door and the extra room and the saving of the LBS would help a bit also.
DRZ2021 is offline   Reply With Quote
Old 06-29-2016, 06:43 AM   #13
Wolverine 1945's Avatar
What ever works !!!
If I were to remove the door I would take very good care of it,,, so if & when I wanted to sell the unit I could replace it !!! I just don't see the weight or the fact it sticks out a couple of inches being a problem !!! We have never closed ours,,, but I see it getting used,,, maybe if some one wanted to take a nap,,, or go to bed while someone else wanted to watch TV,,, or what ever !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-29-2016, 10:31 AM   #14
Originally Posted by Wolverine 1945 View Post
What ever works !!!
I agree I would store it safely to reinstall at a later date. I am thinking of putting a couple nice double coat hooks on the wall as there is not really anywhere to hang a towel or jacket. Might put them on the other side of the bedroom entry door under the TV mount.
Old 06-29-2016, 03:14 PM   #15
I mounted a 1x4 where the door had been. I stained it to look like the other woodwork and mounted it pretty solidly into the wall supports rather than the 1/4 inch wall material. I mounted a towel bar and two robe hooks on it...
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 06-29-2016, 03:40 PM   #16
Very nice. I may copy your idea only use smaller coat hooks.
Old 06-29-2016, 04:59 PM   #17
I had previously installed smaller hooks in various locations...but found that things liked to fall off of them. So I went with the larger hooks this time.
Dave
2015 Solera 24R
Old 06-30-2016, 07:16 AM   #18
I used a couple of fairly large Command Hooks,,, on the other side under where the TV would mount !!! They hold up real well !!! Our Menards has a HUGE display of Commend stuff !!!
Old 06-30-2016, 12:00 PM   #19
Dave how did you anchor the 1x4 to wall?
John Craft
dogpa
2016 Solera 24R
Tow 6X12 Enclosed
dogpa is offline   Reply With Quote
Old 06-30-2016, 01:26 PM   #20
I drove screws, at 45 degree angles, at both ends of the board. The screws were angled toward the outside so they screwed into the same corner supports that the thin wall material is stapled into. (Definition of an RV? "Sticks and Staples"!)
Dave
2015 Solera 24R
bed, door, roo
