Old 06-26-2016, 05:35 PM   #1
Remove sliding bedroom door in 24R
I do not see us using the wood sliding bedroom door in our 2014 24R. Has anyone removed it? Seems to be sturdy so I assume weigh saving would be nice. Any issues with removal or reinstall it?
DRZ2021 is offline   Reply With Quote
Old 06-26-2016, 08:58 PM   #2
I pulled ours off for the same reasons you stated. Comes off easily. The door hangs from pins that slide in the track. The pins are locked by a small cam arm in the brackets mounted on top of the door. 22000 miles and many months of traveling haven't missed the door yet.
JohnHenry is offline   Reply With Quote
Old 06-26-2016, 08:59 PM   #3
I removed mine. I replaced it with a curtain. I bought a couple of the runners that fit in the track in the ceiling and attached the curtain to them - five in total...I think.
It's a hollow core door, so the weight savings isn't all that much. Much more weight savings when replacing the glass shower door...
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is online now   Reply With Quote
Old 06-26-2016, 11:21 PM   #4
Dave
Ours came with a shower curtain not a shower door. Not sure if that is the way it came from the factory or if the PO changed it out.
Another reason I wanted to remove the sliding door was to give just a bit more room in the bedroom. Not much but it seems like you should feel the difference especially with the slide in.
Old 06-27-2016, 12:38 AM   #5
Removed mine for easier access to bed and a little weight savings. Where are the shower curtain replacements coming from?
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 06-27-2016, 06:57 AM   #6
Here's a link to a discussion on RV.net which includes pictures of the SEA shower curtain and contact info on how to order:
https://www.rv.net/forum/index.cfm/f...print/true.cfm
This is the same unit that FR is using. As I recall, total cost was about $140 including shipping. It comes in both a "platinum" and an "oiled bronze" finish, but the oiled bronze seems to be pretty scarce.
I had some issues getting it installed correctly and they were very helpful. (The curtain is held closed by a couple of magnetic strips - one on the door, one on the jam, and I had problems getting them to line up correctly... And the installation instructions suck.)
Dave
2015 Solera 24R
Old 06-27-2016, 10:26 AM   #7
Thanks Dave. I might wait on the shower door as we hardly use it but would really like to get rid of the weight.
John Craft
dogpa
2016 Solera 24R
Old 06-27-2016, 10:49 AM   #8
Did the shower curtain come as an option or did my 24R's previous owner make the switch? How do I tell? I can not see any signs of a retrofit or marks of a door being in place. Seems odd that they would do that as everything else including all labels on the oven hoods are still in place. They had it for a year but drove it a total of 1,300 miles.
Old 06-27-2016, 12:10 PM   #9
Mikegjax's Avatar
The 2013 24R came standard with a curtain. When I ordered my 2014 it was supposed to have a curtain but came with a glass door. I did not like the curtain and will stick with the added weight. I use the shower whenever using the RV.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-28-2016, 08:00 AM   #10
Wolverine 1945's Avatar
That hollow core door probably weights less that a pair of boots ???
LOL !!!
Wolverine 1945 is offline   Reply With Quote
bed, door, roo
