Old 10-27-2015, 05:10 PM   #11
Mikegjax's Avatar
Originally Posted by Pedrodasdas View Post
And where can we buy this product? ACF 50 I mean .
Don't buy it yet. I am going to give it a couple more weeks and will post my final findings.
However I do recommend ACF 50 as a corrosion inhibitor. I use it on my battery terminals, boat wiring connectors, motorcycle and anywhere there is corrosion or could be corrosion. If you like WD40 you will love ACF 50.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 10-27-2015, 05:54 PM   #12
just use a wax that leaves no white residue and can be used on all surfaces like:
latner is offline   Reply With Quote
Old 10-27-2015, 07:42 PM   #13
Mikegjax's Avatar
Tried a similar product that could be used on everything. Honestly did not like it. Went back to NuFinish.
2014 Solera 24R
USN Retired
Old 01-11-2016, 08:09 PM   #14
Wax remover
I had the same problem with wax on trim of our CRV and found Awesome Cleaner from the dollar store would remove it. I haven't tried it on the RV yet other than it cleans just about anything.
2015 Solera 24S
tominfl is offline   Reply With Quote
Old 01-13-2016, 05:15 PM   #15
Total Loss's Avatar
I used to detail cars, trucks, rv's and boats.
My trick was to be VERY careful around any plastic.
I used cotton gloves and applied the wax with my fingers around the trim.
Cut down on the removal and or coverup of the haze.
One will still get some on the trim from time to time.
A toothbrush is your friend.
I chewed on one between my teeth usually when buffing- always at the ready. (or kept it in my apron pen holder)
If you get it quick and toothbrush it out (soft bristle), many products will work fine.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 03-31-2016, 02:01 PM   #16
Send a message via Skype™ to Pedrodasdas
Finally discover Mister Clean Magic Eraser.
A friend of mine suggest it to clean my awning, it did great with no pain.
Then, I tried it to remove bugs , awesome ! No sweat, no scratches, easy!
Then I told myself what about those black trim with old wax = magic.
Works great on door trim and front bumber and decals too !
The only problem is that the black trim are not smooth then the eraser will desintegrate rapidly but, at $1,00 a piece (Great Value WalMart is $1,89).
Great find !
ID:	103456   Click image for larger version
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
Old 03-31-2016, 02:22 PM   #17
Flybob's Avatar
Try Back to Black and a brush. Available at most any auto parts store.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
