Old 06-21-2016, 08:15 PM   #1
Needs Help
Replace City Water Inlet
I need to replace the city water inlet on my Solara 24S. Have any of you found a good replacement that will last longer than the plastic one it came with?
2014 Forest River Solera 24S
Living_The_Dream is offline   Reply With Quote
Old 06-21-2016, 08:19 PM   #2
Oaklevel's Avatar
Never had one break but you should be able to get a better quality one at any RV dealership.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 06-21-2016, 08:37 PM   #3
caper's Avatar
We replaced ours with a brass check valve 4 years ago and have not had a problem.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 06-21-2016, 08:51 PM   #4
Needs Help
I will swing by my dealer and see if they have something that looks more robust. Thanks for the feedback. I took the three screws holding the flange out and I could not pull the line down far enough to get to the nut. Looks like some double jointed work, or maybe I can use pliers on it.
Looks easy enough to pull. I left it on so the system didn't drain without me being there to direct flow.
Old 06-21-2016, 09:09 PM   #5
Left Coast
When you replace the fitting, buy a 90 degree fitting so the hose is hang'n down.....
Old 06-21-2016, 09:13 PM   #6
Ford Idaho's Avatar
Just a thought on my part as I am not familiar with your units lay out.
Is there a storage bay next to the connection?
Could there be a false panel that would allow east access?
Old 06-21-2016, 09:14 PM   #7
DocsDad's Avatar
Installed one in the spring that I picked up on Amazon. Haven't used city water since ... lol. Brass fittings seem much better than the plastic OE inlet that cracked. Easy install. You might want to pick up some fresh putty tape to help seal things up. I also used a silicone for good measure.
https://www.amazon.com/s/?ie=UTF8&ke...l_5gp87fu7wp_b
2016 Forest River Sunseeker 3100SS
DocsDad is offline   Reply With Quote
Old 06-21-2016, 10:03 PM   #8
Needs Help
The fitting for mine points almost directly down. It's in a compartment of its own with the other stuff like sewer and stuff so no access from the rear. I can pretty easily get to the nut, I just need to reach up behind the panel it hangs down from.
Not sure what I would need the putty tape for. Not breaking any seals with the exception of the water line.
water
