Old 08-11-2013, 10:29 AM   #1
Replacing the Flexible Fiberglass/Rubber Tire Stems
Just found my right rear inner tire loosing air when I checked the tire pressure at 40 lbs (Continental Tires rated @ 80 lbs) yesterday. I have the flexible fiberglass stem going to that tire. I made up my mind to replace and am now getting quotes. I have one quote @ $321.59 total for (6) tire breakdown and replace stems with “Airless” stainless steel stems. Appreciate any other stem recommendation/advice before I pull the trigger and buy. Thanks.
2013 Solera 24S
PS: I find it hard to believe that Forest River would sell an RV with the stem problems as stated on this forum without some liability issues.
CaptDan is offline   Reply With Quote
Old 08-11-2013, 10:42 AM   #2
2012 Solera
Tie up your valve stem extenders with wire ties. Also tie the wheel covers to the wheels. My experience is the valve extenders whip around when driving and can depress the valve stem letting air slowly seep out. No problem after tie up. If this is a new problem could you have a nail in the tire?
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 08-11-2013, 01:31 PM   #3
hkreck's Avatar
I have over 15000 miles on my 2013 Solera and have not had any problems with the tires. I am thinking about replacing the valve stems and extenders when I have the tires rotated. But that probably won't be until next year now.
Henry & Tena
hkreck is offline   Reply With Quote
Old 08-11-2013, 05:43 PM   #4
DavidS's Avatar
If you have airless stem extensions (Inflators) installed you may have issues with stem mounted tire pressure sensors.
DavidS is offline   Reply With Quote
Old 08-11-2013, 06:38 PM   #5
hkreck's Avatar
Thanks for the advise.
Henry & Tena
Old 08-12-2013, 02:29 AM   #6
Commercial Member
Originally Posted by CaptDan View Post
[FONT=Times New Roman][SIZE=3]
The issue was with the stainless steel braided ones that attached to the wheel liner. Wheel liner goes flying off...so does the extension.
The Yellow Air-Flexx ones are airless...so only release air when the center stem is depressed. They do not attach to the wheel liner (by design). You can look up Air-Flexx for more info.
Glauch Air-flexx
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
tire
