Old 06-19-2015, 05:16 PM   #1
Solera 2013 24S
Retractable Step
Can Anyone give me instructions on how to lube the retractable step? It won't open, I can hear the motor trying to open so it is not the .thanks
Leismom is offline   Reply With Quote
Old 06-19-2015, 05:23 PM   #2
Do you have the step switch in the correct position? If not, the step might make a noise but not open. My LCI instruction booklet said it does not need lubrication. I have a 2014 24R.
2014 Solera 24R
David100 is offline   Reply With Quote
Old 06-19-2015, 07:24 PM   #3
Look at this post;
Solera retractable step fuse location
See post #7 and follow those steps, that will fix your step issue.
Old 06-20-2015, 11:56 PM   #4
My step wouldn't open either but sounded like it was trying to. Problem was not lubrication but a broken bolt that dealer found and repaired.
jngspencer is offline   Reply With Quote
Old 06-21-2015, 12:02 AM   #5
On a Solera?
Old 06-21-2015, 10:15 AM   #6
Broken Bolt
Same Problem I had and repaired.
See thread Door Step - Need Help
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 06-21-2015, 11:00 AM   #7
Yes on a 2015 Solera 24R.
Old 06-21-2015, 12:03 PM   #8
Solera 2013 24S
Thanks for all the replies, It seems all it needed was some good ole WD40.
