Old 09-30-2015, 12:48 PM   #1
Reversing faucet direction
On my 2016 MBS the H control on the shower and C control on the sink are reversed so you turn them clockwise to turn on. On a previous RV I owned I corrected this by removing the internal valve and turning it 180 degrees. I turned the valve on this faucet 180 and it didn't change anything. I remember the older style valve had stops on the top and this one doesn't.
SSmbs is offline   Reply With Quote
Old 09-30-2015, 01:34 PM   #2
There are several threads on this.
Backwards Faucets
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
tmhudg is offline   Reply With Quote
Old 09-30-2015, 04:04 PM   #3
I can't find any posts on this new style of valve. The style shown in the link you provided is for an different version (shoulders on valve body)that I know how to fix.
Old 09-30-2015, 04:07 PM   #4
Instead of the term shoulders I should have said valve stops. Mine do not have the valve stops as shown in the link.
Old 09-30-2015, 04:18 PM   #5
Head Rambler
Can you post a picture of them with the handles removed?
Gotta go campin!
Old 09-30-2015, 04:36 PM   #6
Did you actually pull the cartridge out and look on the bottom for the small steel tab? I know that I initially tried just turning the cartridge and it didn't help. I had to actually take the metal tab off of the bottom of the cartridge and turn it 90 degrees and then the handle rotated the correct way. Well, the handle would rotate the right way *and* the water would come on/off appropriately.
Yeah, take a picture with the handles off and also a picture of the cartridge.
Old 09-30-2015, 05:58 PM   #7
I see the small steel tab. Turn 90 or 180 degrees?
Old 09-30-2015, 06:18 PM   #8
Old 09-30-2015, 06:23 PM   #9
So your saying just reverse the metal tab? I see there is a teardrop shape to the metal tab.
Old 09-30-2015, 06:33 PM   #10
Head Rambler
You're supposed to rotate the plate 90deg, but I don't think you can do that on that cartridge.
Can you take a picture of the inside of the faucet with the cartridge removed?
Gotta go campin!
faucet
