Old 02-25-2012, 10:56 PM   #11
GM
bclemens's Avatar
Originally Posted by papap View Post
Not sure how those would work with TPM on them.
If you're talking about the nozzle mounted ones they would not. You would have to use a internal "wheel mounted" system that comes on cars these days.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-26-2012, 11:26 AM   #12
papap's Avatar
I still think. This should be a safety recall by Forest river to fix. I can see it now. Someone getting in a wreck or even killed because of this problem.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 02-26-2012, 11:44 AM   #13
papap's Avatar
anyone know of a good brand of internal tire pressure monitors?
Old 03-05-2012, 07:32 PM   #14
Driver side rear tire slow leak
I tested my Outside driver rear tire and it was empty. i fiiled it and it held for one day and lost 10 lbs. Filled it again and same slow leak. 2011 Solera
Gonzo is offline   Reply With Quote
Old 03-06-2012, 07:14 AM   #15
papap's Avatar
Sounds like you have a nail in the tire.
Old 07-18-2012, 06:36 PM   #16
I have the same problem on my 2010 Solera. Rear wheel covers are loose and noisy. The right cover has come off and is connected only by the valve stem extensions. I've zip tied them, but I think the factory should recall them and replace them with higher quality covers. Anyone found a good after-market wheel cover?
scarlton46 is offline   Reply With Quote
Old 07-18-2012, 06:38 PM   #17
TURBS's Avatar
Midwest Wheel Companies - Home sells a high quality one we have used before and had great success .
here http://www.midwestwheel.com/specials...Simulators.pdf
Old 07-19-2012, 12:07 AM   #18
Thanks. I'll call Midwest Wheel to see if they have a 16" wheel cover for the Sprinter 3500.
