Old 10-27-2014, 11:00 AM   #11
Originally Posted by HomeOnWheels View Post
Very cool. Wonder where you get one... Maybe you have to modify an existing ladder?
DaveJordan is offline   Reply With Quote
Old 10-27-2014, 02:51 PM   #12
2015 Forester MBS 2401W
HomeOnWheels's Avatar
Here is the original post on CL. See if you can contact the owner for the information. Good luck.
2014 FOREST RIVER SOLERA Class C RV
HomeOnWheels is offline   Reply With Quote
Old 10-28-2014, 09:21 AM   #13
FYI - I contacted the seller about the ladder. He said (and I quote):
"Good luck. I made it myself."
Dave
PS - Thinking about it, I suspect that making such a ladder wouldn't be too hard. If you started with a ladder designed for a different Solera floorplan you could just cut down the length of the treads, drill new holes for the supports, and mount it where he mounted it. Nah, maybe I'll just take one of those telescoping ladders!
Old 10-29-2014, 11:34 AM   #14
devilsquid's Avatar
Originally Posted by bclemens View Post
I'm guessing the 1/4" plywood was a CYA response. The first time you put a chair up there to watch a race, the rubber tip is off the chair leg and it goes through the fiberglass...then we get a warranty claim.
I walk on them to inspect stuff as well. never had an issue. As always a large dose of common sense normally covers it.
I agree with BC use a healthy dose of common sense. It would seem to me that placing a sheet of plywood (to distribute weight???) would be a safety hazard...plywood thick enough to distribute weight on a convex fiberglass roof increases the probability of falling off...IMO. I've been up on my roof many times inspecting and trying to place the RV cover (not needed anymore...new carport) without problems but then again we have a 2013 S.
devilsquid is offline   Reply With Quote
Old 10-29-2014, 05:07 PM   #15
Mikegjax's Avatar
I get on my 24R roof quite often to was and wax. That is a strong roof.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
roo, roof
