Forest River Forums
Sunline User Photos
Old 09-27-2011, 01:44 PM   #21
Send a message via Skype™ to Pedrodasdas
I have already check all those fuse with a tester, no luck, still looking. Thanks.
Pedrodasdas is offline   Reply With Quote
Old 10-07-2011, 04:41 PM   #22
Update: Still working on the problem.
Found out there are no fuses controlling the lights, just a Big Magic Box under the dash. Why MB has to put computer everywhere ???? Drives me creazy !
So far, I have isolated section of lights:
I can make the front identification markers works.
I can make the rear identification markers works.
If I try to connect both at the same time, everything goes out.
Why ? why ? why ?
Can it be that 10 markers draw too much current ? It was working before !
Old 10-07-2011, 05:34 PM   #23
Update of the update:
It is exactly that. If I put too many lights, the computer that runs the light shut off. Can you imagine that ?????
The only solution: Go to MB dealer to have the computer reset with the right amp.
My solution: Run a new wire from the fuse box under the driver's seat to the main light wire at the rear. Fuse number 2 is free and comes on only when ignition is ON.
I will let Freightliner dealer take a look at it on my way South next month and have the oil change at the same time.
Old 10-10-2011, 09:16 AM   #24
Final post:
Problem: All running lights are gone.
Cause by: A computer monitor the Amps that goes to the light. Factory set is for 4 bulb lights. FR and MB has to fooled the system so it will provide enough Amps for 12 markers and 4 LED's. Each time the system cut-off, it will reset to factory set and will cut the power.
Solution A: Go to MB dealer to have the computer reset to 16 lights, it will probably cost you around $150.
Solution B: Run a new power wire from battery or fuse box to the FR light panel hidden in the hook-up compartment. Connect it to a relay and use the MB wire to feed the relay. That way, the computer will never feel overcharge. Damn I hate computers in vehicle.
» Online Users: 604
102 members and 502 guests
4-2-6, 4bnabird, Al Fresco, Barney1, biggie, bikendan, Bill_C, bouldercamper, bradyashton, Cafjackracing, Canuck_Doug, caper, cbj, CC Steve, ccyake, chadvc, COcamper, cpope84, cyclepuck, dashonthedash, dasimser, david-o, daw592, dawg82, ddemme, DGrissom, Dodge Guy, DonG, donn, dware1962, Elidh, ERRT, etbt1216, Fire Instructor, Fitchy, FLBBQMAN, FreedomTracker, frfan, GASPEDDLER, Go Camping, herk7769, Iggy, imabmwnut, Indy Steve, JamesR, jd-ford-hd, JDWeir, jimh, jmlocke, Jnied, Jo54, JoeR, JoeyO, jrat, jsutherl, KKapa, Kman9936, kvn4th, kz08h5, lami, lowbubba, low_flyer, lurch, MikeFletcher24, Mpjduff, Mpwelch50, Msaunders, mtofell, N3HCP, nailit, Namchief, newtsx3, nightcrawler, nrcamp, OffPavement, pappcam, pbrackney, pchrcane65, polkatronron, PrairieBoy, QDog, racerx, RalphieG, Rebel702, ret2006, RichardE, Rsgtivr6, sandys, seatosea, snjparham, softwarejoe, stevengb, Swinks, tabkld93, Terier, Triguy, troyt, unhcharger25, wayne anthony, Whiteknight, william.migues, wvfireboss
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
