Old 09-26-2016, 02:41 PM   #1
Running Board Step Pads
I need to replace one of the running board step pads on my 2014 Solera (chassis is 2013) and would like to find the exact same one that is on there now, but I can't seem to find one. It is 4-1/2" wide by 19-1/2" long. Does anyone know where I can get one?
Thanks,
Steve
ID:	121364   Click image for larger version
2014 Forest River Solera 24S
sclod is offline   Reply With Quote
Old 09-26-2016, 03:16 PM   #2
You might check with Forest River part/service. They may have the exact thing. Otherwise, these guys have tread available by the foot:
CPC Parts
If it doesn't match, you might just replace both sides.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is online now   Reply With Quote
Old 10-05-2016, 12:39 PM   #3
I assume you lost one of the treads while traveling. One of mine was beginning to come loose. To prevent further detachment or loss, I put a stainless screw in each end of both mats (2 screws each), screwed into the fiberglass step. They look like they are supposed to be there.
Mark, Susan and Barney the SheltiePoo
2016 Forester MBS 2401WS
Wrangler Toad with NSA Ready Brake
barnbnb is offline   Reply With Quote
Old 10-05-2016, 03:29 PM   #4
Yes, I lost it while traveling. Did you use a special kind of screw? Did you drill a hole first?
Old 10-06-2016, 08:13 AM   #5
I used short stainless steel screws and drilled pilot holes.
