Old 11-27-2015, 12:12 PM   #11
MNtraveler's Avatar
Watch out for "concentrated" bleach which is somewhat common today. It is not quite double strength.
http://www.waterandhealth.org/high-strength-bleach/
Name:	ImageUploadedByForest River Forums1448647921.176540.jpg
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-27-2015, 12:20 PM   #12
When I had my boat I had 100 gallon fresh water tank. I use to sanitize with bleach but didn't like the bleach smell that lingered. I since then started using chlorine crystals. I used one teaspoon for 100 gallons. Then fill the tank with water. Run the water through all the lines. Wait an hour and empty the tank. Fill the tank again and run the fresh water through all the lines until the tank is empty. The smell of chlorine does not linger as much as bleach. I then would at a quarter teaspoon of chlorine and fill the tank to chlorinate the water. I will do the same with a 60 gallon tank but only use a half teaspoon of chlorine to sanitize it.
djeirlessr is offline   Reply With Quote
Old 11-27-2015, 01:22 PM   #13
Originally Posted by Ford Idaho View Post
1/4c-16g if I figured right.
When I typed "G" I meant gallons, not grams.
CNYCamper is offline   Reply With Quote
Old 11-27-2015, 01:44 PM   #14
Ford Idaho's Avatar
I missed the shift button, did not think it worth the effort to edit.
Old 11-27-2015, 03:08 PM   #15
What specific product do you use? Can you point us to a web site that sells it?
Thanks!
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 11-27-2015, 04:32 PM   #16
I'm not sure of the name. I will look for the container I have. I bought it at a store that sell pool and patio supplies. I have a 2 pound container that lasts a long time. When I find it I'll post it.
Old 11-27-2015, 05:27 PM   #17
Islander's Avatar
water - then - bleach
Recalling my earlier working careers.. one being a bricklayer, we were taught to 'always' place the water in the pail first before adding the muriatic acid (now called hydrochloric acid) ..used for washing down the masonry.
I would recommend doing the same with 'bleach'.
The reason for doing it this way is so the bleach (or any toxic / hazardous liquid) does not splash out - onto -or- in - unwanted places or things should the water be poured in second.
However, having said that, if the bleach is poured into the tank first it really shouldn't cause any 'splash' danger down inside the enclosed tank.
On the other hand if mixed in an open container the water goes in first.
hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 11-27-2015, 05:42 PM   #18
Kaadk's Avatar
Last spring I just added some water to the fresh tank, then poured in some bleach, then added more water.
But getting the bleach into the tank was a bit of a pain. Probably spilled 2x what I got in the tank.
I think this spring I'll either:
A) put some bleach directly in the filter canister, then run water through.
Or
B) make a solution in a separate jug and use the antifreeze pickup.
Not sure which way I want to go yet. A is easier and more likely the way I'll go if I'm feeling lazy. B gets more components.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 11-27-2015, 05:50 PM   #19
Who Dares, Wins
doc73's Avatar
I used my one gallon jug to make the solution in and poured that into the gravity fill port.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 11-27-2015, 06:36 PM   #20
Sagecoachdriver's Avatar
Does your Solera have a water system filter? If so, you are probably only sanitizing only the tank. The filter removes the chlorine before it goes into the water heater and lines. Take a look at the flyer on the Solera, it shows the filter. http://www.forestriverinc.com/brochu...leraposter.pdf
What I did once to sanitize was fill a jug with some water and added bleach. Then I turned the valve to winterize and put the draw hose into the jug and pumped the bleach solution thru the lines until I could smell it coming out the faucets. Let is sit a while and then used the low point drain to remove the bleach solution to a bucket for safe disposal and then switched the line back to normal use and ran the faucets a while to clear out the rest of the bleach solution. Too involved for me to do that often.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
