Old 06-09-2013, 02:19 PM   #11
Broadway Joe's Avatar
I used pretty much the same procedure but used a lot more bleach, not knowing what the previous owner had or hadn't done to the water system. Just make sure you use unscented bleach, and rinse thoroughly.
Broadway Joe is offline   Reply With Quote
Old 06-09-2013, 09:16 PM   #12
2012 Solera
Originally Posted by Slow_movin View Post
Did you drive to AK or use the AK Marine Highway? I would love to drive to Homer and catch them barn door halibuts..Generally use North Country Charters.
Sent a PM. Don't want to hijack this thread.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-10-2013, 07:04 AM   #13
This got me to thinking, I put about a cup of clorox in my curbside trash can to keep the smell down. Would it cause any harm to the toilet or black water tank if I did the same?
DebbieMH is offline   Reply With Quote
Old 06-10-2013, 08:39 AM   #14
It will cause a ton of harm to any septic system you dump your tank into (kills the good bacteria that septic systems rely on).
Old 06-10-2013, 09:07 AM   #15
Ok thanks. Figured there was a reason.
Old 06-11-2013, 06:40 AM   #16
Gripper's Avatar
Thought I would share this link in response to the orignial post
How to Sanitize Your RV Fresh Water System
Essex County
Southern most area in Canada
2017 F250 Lariat 6.7superdutyTurbo Diesel
2011 Flagstaff classic 31.5'BHDS
Gripper is offline   Reply With Quote
Old 06-11-2013, 06:57 AM   #17
If you already have water in the fresh water tank, leave it there and use the proper amount of bleach for a full tank and then fill it up. I remove my filter after I release the pressure on the lines by shutting off the pump and then open up a tap.. Run the bleached water through the water lines via your pump until you can smell the bleach in the water coming out of the taps, both hot and cold. Remember your outside shower. You can also just use the city water connection to clean your water lines and water heater only. Pour the required amount of bleach into a hose, connect to the trailer and run it into the water lines that way. Don't open up the taps until you're able to go to each one and wait for the bleach smell in the water. I usually let the water in the tank sit overnight before I flush it out with fresh water.
Pipeman is offline   Reply With Quote
Old 06-17-2013, 09:56 AM   #18
ilmor's Avatar
The owners manual explains the entire process and requirements very well. I just follow it.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 06-18-2013, 01:05 PM   #19
Thanks all. I knew the steps were in the manual, but they left me with questions. Taking the filter out now seems to be my sticking point. Thanks again!
Marionap is offline   Reply With Quote
