screw loose
finding a wing nut at the bottom of the pantry got me to look around
first, the wing nut was from a bolt at the top of the pantry slide,
bolt was half out, replaced and tightened that and the companion in back
then went around checking all cabinetry hinges, some needed tightening
btw: there is a large screw to tighten, also a small screw for alignment that
should only be adjusted if necessary
_________________
2014 MBS Solera 24S
