Old 11-01-2013, 08:28 AM   #1
Seatbelts on 24S and 24R dinette?
Can you add seat belts to the S and R dinette if they are installed initially? How many can be added? Hopefully four?
Thanks!
RyderD is offline   Reply With Quote
Old 11-03-2013, 06:03 PM   #2
Our 2011 24S came with seat belts on one side of the dinette only. I thought maybe it was because the rear facing seats had the window behind them in the slide out and maybe they didn't want people sitting there.
I was told by a factory rep at an RV show that the lack of seat belts is strictly for weight ratings. For each seat belt installed by the manufacturer, they have to factor in a certain amount of weight, which then needs to be subtracted from how much weight can be carried and that doesn't look good to consumers. By leaving the seat belts out, it means more weight can be added. Of course that also means that if you are carrying more passengers than you have seat belts, those passengers need to be factored in to the carrying capacity.
Ogsarg is offline   Reply With Quote
Old 11-03-2013, 09:45 PM   #3
The 24R has seatbelts as described by Ogsarg above
kidagn11 is offline   Reply With Quote
Old 11-04-2013, 08:13 AM   #4
Can you add seatbelts after-market? Will a dealer do that?
Old 11-04-2013, 08:50 AM   #5
GM
bclemens's Avatar
Depends on the dealer and whether they want to take on that liability.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
