Old 05-08-2015, 01:42 PM   #1
Phinias's Avatar
Sewer Hose Receptical
Does anyone know haw long of a quality hose with coupling the storage tube on the Solera 24 R will accommodate?
Phinias is offline   Reply With Quote
Old 05-08-2015, 01:57 PM   #2
Mikegjax's Avatar
The storage tube will not accommodate a hose with a coupling on both ends.
The hose that comes with the unit has a coupling on one end only.
If I use that hose I add a coupling while in use and then remove for storage.
Maybe someone else has found a tube with a small enough coupling to fit in the tube, but I have not. It is kind of a waste of space IMO.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-08-2015, 02:01 PM   #3
I just grind the little tabs off the outside of the couplers to where they will fit in the tubes.
Old 05-08-2015, 02:02 PM   #4
Phinias's Avatar
how long of a hose
Old 05-08-2015, 02:05 PM   #5
how long of a hose
(2) 15' in one tube.
Old 05-08-2015, 02:06 PM   #6
Ecopco's Avatar
We were able to put 20 feet of hose below in the sewer compartment. It's a tight fit but it works!
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 05-08-2015, 02:11 PM   #7
We have (4) tubes just shy of 8' each, 2 round perforated and 2 square ones.
Old 05-08-2015, 02:24 PM   #8
Phinias's Avatar
I realize that with a little imagination I can travel with a couple of hundred yarfs of hose.
I jusst traded a Pleasure Way 3500 Super Van. I traveled the country for 9 years. It had a similar storage compartment. It would a accomodate a one ended hose that worked for me 99 percent of dumping. That;s wahat I need to know. How long of a open ended hose with a connector on the other end will the hose compartment accept?
Old 05-08-2015, 02:27 PM   #9
My bad, didn't realize you were talking about a MH.
Old 05-08-2015, 02:50 PM   #10
Mikegjax's Avatar
The compartment (tube) is 24" deep from the inside of the door. So any hose you could compress to less than 24" would work (- the one end).
2014 Solera 24R
USN Retired
