Old 12-31-2015, 01:26 PM   #1
Shower door lock
Any info on/how to get a replacement shower door lock for a Solera 24R?
tks J
jfshagar is offline   Reply With Quote
Old 12-31-2015, 05:54 PM   #2
Mikegjax's Avatar
What is wrong with the current one?
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-01-2016, 09:13 AM   #3
Shower Door Lock
tks J
We have a 2014 24R and it didn't take long for the black plastic shower door latch to break. I looked EVERYWHERE ONLINE and did not find it, so I ordered one from a Dealer. It is a whopping $10 for a piece of plastic. I can get you the part number if you like.
Funny thing - now that I have the lock, I just took receipt of a new vinyl shower door that replaces the entire glass door unit. However, because we are in NE Ohio, I won't be installing it until the weather breaks in the Spring !
Hope that helps,
Jeff N.
nusslejj is offline   Reply With Quote
Old 01-01-2016, 09:35 AM   #4
Mikegjax's Avatar
If the hook part came off and is not broken, it can be snapped back on.
2014 Solera 24R
USN Retired
Old 01-01-2016, 09:43 AM   #5
Hey Jeff,
Could you provide details of the vinyl door? Manufacturer, part number, where you bought it, how much it cost, how big a deal you think it will be to install ... and anything else you think might be relevant?
Thanks!
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 01-01-2016, 09:47 AM   #6
A good temporary fix if you shower door latch breaks
You can't have the door banging back-and-forth as you travel, so when I got home from camping I happened to have a spare 2'-3' piece of that black styrofoam water pipe insulation - it is like 2.5-3 inches around, and quite flexible.
I cut it to the length of the shower door bottom track when the door is open (plus an inch or so), then slit it lengthwise and pressed it into the bottom rail. It really works well - the door does not move, it is easy to put on/take off, and it doesn't wear out !
Old 01-01-2016, 09:48 AM   #7
RedLdr1's Avatar
Jeff,
+1 on Dave's request for info on your replacement door. Our glass door will be out this spring one way or another...
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 01-01-2016, 09:56 AM   #8
A Better RV Shower Door
Originally Posted by DaveJordan View Post
Hey Jeff,
Thanks!
Here is the thread and some pics on what I purchased. I think it will be a bit challenging to install because the instructions/illustrations are not great, but it does look to be very well built, and they offered their assistance if you have any questions at all, and even called me back as a followup.
https://www.rv.net/forum/index.cfm/f...print/true.cfm
Call Traico M. and he will happy to help you. It cost around $100 + another $30 or so shipping. It shipped out of Indiana.
Traico Marinoff
Parts & Warranty
Shower Enclosures America
800-536-7324 x3110
Fax: 909-605-7793
Hope that helps,
Jeff N.
Old 01-01-2016, 02:21 PM   #9
for the 24S ( don't know what others look like )
the first time the latch broke, I tried a couple of solutions,
finally settled on a zip tie, around last roller post, and
just loose enough to slip over the end of the mounting rail
I lock the door open always, haven't had it fail in 10K of travel
major advantages:
haven't seen any sign of mold since the shower always dries quickly
area seems roomier with door open
_________________
2014 MBS Solera 24S
ipolyihh is offline   Reply With Quote
Old 01-02-2016, 07:37 AM   #10
Easy fix for the glass shower door movement during flight. Cut a 1/4" wooden dowel just long enough to be wedged between the end of the fixed glass piece and the end of the extruded aluminum piece on the moveable glass door. The dowel should be slightly longer than that distance, when the door is in the closed position. The best placement of the dowel is at the bottom. If you experiment with the length, you will find that only a slight pressure wedging the dowel in position, yet leaving enough length to easily remove the dowel works great. This "fix" is meant for the 24S model.
door, show, shower
