Old 08-23-2015, 01:16 PM   #1
Mikegjax's Avatar
Sirus XM antenna mount
For those of us that do not have the FR installed Sirus antenna I made my own mount for inside the RV. I did have it mounted to the top of the TV, but wanted a different setup. Here is what I came up with if anyone is interested. It is made of a one inch piece of aluminum sheet metal. Bent the end to slip behind the cab-over bed window curtain track. Used the existing track screw in the hole drilled into the mount. 3M double sided tape holds the antenna. Light weight and out of the way. Antenna wire is barely visible.
ID:	86615   Click image for larger version
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-23-2015, 01:37 PM   #2
BendOrLarry's Avatar
My antenna looks like yours and is magnetic. I just put it on the hood just in front of the window. It's not in the way, doesn't move and the wiring to the reciever is close by. Took about 10 minutes to install.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 08-23-2015, 01:42 PM   #3
Mikegjax's Avatar
Mine is also magnetic, but I wanted to use aluminum for the mount (that is what I had laying around). Your mounting is also a good way. I just wanted to keep it inside and out of sight.
2014 Solera 24R
USN Retired
Old 01-14-2016, 01:30 AM   #4
benagi's Avatar
Don't Sirius radio antennas need to be outside to receive a good signal from the satellite ?
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 01-14-2016, 09:00 AM   #5
RedLdr1's Avatar
It might work a little better outside but since the roof isn't metal this is fine...
Another little secret is your XM/Sirius signal isn't necessarily being received from the satellite. Major metro areas, like Atlanta, have local repeaters all over the place. Tall building, and heavy tree cover, kill true satellite only reception.
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 01-15-2016, 12:40 AM   #6
benagi's Avatar
I've heard that . It's works great in town because of the repeaters but very weak or no signal when out in the country. Our unit is at CW now getting warranty work done and the radio is on the list. They said they are at a loss on how to test it in town and they are not going to take it out of town to see the problem. Any ideas how I can trouble shoot while out of town?
1968 tent trailer
1985 Jamboree 23 ft
Old 01-15-2016, 05:15 AM   #7
Thunderbolt75's Avatar
A friend has his mounted to the crossbar inside of a vent dome. Magnet mounts nicely to the galvanized steel and the wire is easily fished into the trim. It has a clear view to the sky.
Be safe, but if you cannot, be violent.
Choose to be a winner, not a victim.
Thunderbolt75 is offline   Reply With Quote
Old 01-15-2016, 06:02 AM   #8
On two Lance campers in the past I riveted a small piece of steel to the top of the roof refrig vent and fished the wire down through behind the refrig and into the cabinet where the radio was. It worked great. Got to test it almost all the way to the Artic Circle on the Dempster Hwy. but fires forced us to turn back. Needless to say it was VERY sensitive to hills and trees at that latitude.
dontay is offline   Reply With Quote
Old 01-15-2016, 06:28 AM   #9
Mikegjax's Avatar
Again, mine works great mounted on the inside near the ceiling away from any metal that might block the signal. I have traveled throughout the country without any problems. You can get some signal block when down in a valley or some obstruction between antenna and satellite, but that is rare.
2014 Solera 24R
USN Retired
Old 01-15-2016, 08:59 AM   #10
RedLdr1's Avatar
Two possible test options: If the radio unit has a built in Signal Strength display you could use it. Contact the radio manufacture to see if they have any "hidden" diagnostics you can use. Or check a local install shop to see if they can do the test. They would be light years ahead of most CW shops in test capability and knowledge.
I would also make sure FR is well aware that the unit does not work properly and that CW cannot, or will not address the issue. Maybe they can send you to a authorized repair shop out in the boonies to test it on one of your trips.
Wayne and Christine
antenna, mount
