Old 04-25-2015, 08:23 PM   #1
skylight/trapped moisture
2015 Solera S. Notice mositure is trapped between inner & outer liner of skylight. Sun brings moisture out during day & disappears at night, ala hydroponic garden. Does the entire skylight need to be replaced?
motorscooter is offline   Reply With Quote
Old 04-25-2015, 08:53 PM   #2
Boss Hoss's Avatar
Sounds like a seal problem.
I hope someone has a magic cure-I have 3 of them-but none have this problem......
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 04-25-2015, 09:18 PM   #3
Cyber Phrenologist
Radio's Avatar
Yeah you have a seal problem. Or a crack. I had a serious leak in the skylight over my shower. Got up on the roof and found a crack from a hailstone. Got after it with eternabond tape and Dicor lap seal as a temporary fix until the new bubble gets here. A tiny crack lets in a lot of moisture. After you get the outer seal/crack fixed remove the inner bubble and let everything dry out real good.
Plan on dedicating all of Memorial Day weekend to fixing stuff on the camper and that's on the list.
Might as well since the parks will all be full up!
Admin at, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
