09-27-2013, 01:01 PM
Slide Out Hand Crank.
In the event of power failer is there a hand crank for the slide on my 24S?
2013 Solera S
09-27-2013, 02:19 PM
That is a very good question Chill. I'll have to go out and look at my 24S now and see.
Henry & Tena
09-27-2013, 02:25 PM
Chill according to the manual you can order one from Forest River. So I'd say that there is not one that comes with the unit.:-{
Henry & Tena
09-27-2013, 03:12 PM
2018 FR3 30DS
hand crank
on my 2011 Solera 24S on the driver side about midways is a propane tank door. Somewhere almost directly above the tank is a 1/2 inch hex nut that you can turn either way to run the slide in/out. I keep 1/2 inch ratchet and socket just for this purpose.
I don't know if there has been any change in the location of the propane tank since 2011 so you'll just have to try to find the nut....
09-27-2013, 03:58 PM
Believe it is the small center door. I did notice the slide motor there. I'll look when I get back home for the nut.
2013 Solera S
09-27-2013, 03:59 PM
My 2012 S, is right where you said as well. I also thought there was something about disconnecting the power supply to the motor, so not to back feed current when cranking manually. I believe I read to do that on the slide mfg. web site.
09-27-2013, 06:39 PM
On my 2014 24R there is no manual way to close the slide outs, other than
removing a screw that holds the motors, lift the motors from the shafts and then push the unit in by hand. There is a video available on the manufactures web site. Here is a link that might help;
10-01-2013, 09:58 PM
Probably should ask bclemens to weigh-in, this is something we all need to know and understand. I'm a newbee with a 2013 S.......PaDawg
10-03-2013, 08:41 AM
Commercial Member
I think I've touched on this before but...
If your slide has (4) Aluminum tracks on the slide out sidewalls, then it is a Lippert IN-Wall slide. it is retracted using the video above.
If your slide has rams below the floor then it is a Lippert below floor slide and it will have a manual retraction shaft coming out of the motor. That shaft will be on the roof of one of the outside compartments or above the propane tank...can't remember exactly.
10-03-2013, 03:21 PM
BC, is there an advantage to one slide out system over the other?
2014 Solera 24R
USN Retired
10-03-2013, 03:25 PM
Commercial Member
Not really. Pros and cons to both. The In-Wall is lighter, but a little more finicky.
