Old 09-27-2013, 01:01 PM   #1
Slide Out Hand Crank.
In the event of power failer is there a hand crank for the slide on my 24S?
2013 Solera S
CHILL is offline   Reply With Quote
Old 09-27-2013, 02:19 PM   #2
hkreck's Avatar
That is a very good question Chill. I'll have to go out and look at my 24S now and see.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 09-27-2013, 02:25 PM   #3
hkreck's Avatar
Chill according to the manual you can order one from Forest River. So I'd say that there is not one that comes with the unit.:-{
Henry & Tena
2013 Solera 24S
The Great Escape
Old 09-27-2013, 03:12 PM   #4
2018 FR3 30DS
hand crank
on my 2011 Solera 24S on the driver side about midways is a propane tank door. Somewhere almost directly above the tank is a 1/2 inch hex nut that you can turn either way to run the slide in/out. I keep 1/2 inch ratchet and socket just for this purpose.
I don't know if there has been any change in the location of the propane tank since 2011 so you'll just have to try to find the nut....
Slow_movin is online now   Reply With Quote
Old 09-27-2013, 03:58 PM   #5
Believe it is the small center door. I did notice the slide motor there. I'll look when I get back home for the nut.
2013 Solera S
Old 09-27-2013, 03:59 PM   #6
My 2012 S, is right where you said as well. I also thought there was something about disconnecting the power supply to the motor, so not to back feed current when cranking manually. I believe I read to do that on the slide mfg. web site.
2012WhiteSolera is offline   Reply With Quote
Old 09-27-2013, 06:39 PM   #7
Mikegjax's Avatar
On my 2014 24R there is no manual way to close the slide outs, other than
removing a screw that holds the motors, lift the motors from the shafts and then push the unit in by hand. There is a video available on the manufactures web site. Here is a link that might help;
Mikegjax is offline   Reply With Quote
Old 10-01-2013, 09:58 PM   #8
Probably should ask bclemens to weigh-in, this is something we all need to know and understand. I'm a newbee with a 2013 S.......PaDawg
PaDawg is offline   Reply With Quote
Old 10-03-2013, 08:41 AM   #9
GM
bclemens's Avatar
I think I've touched on this before but...
If your slide has (4) Aluminum tracks on the slide out sidewalls, then it is a Lippert IN-Wall slide. it is retracted using the video above.
If your slide has rams below the floor then it is a Lippert below floor slide and it will have a manual retraction shaft coming out of the motor. That shaft will be on the roof of one of the outside compartments or above the propane tank...can't remember exactly.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 10-03-2013, 03:21 PM   #10
Mikegjax's Avatar
BC, is there an advantage to one slide out system over the other?
2014 Solera 24R
USN Retired
slide, slide out
