Old 06-30-2015, 02:09 PM   #1
Slow running lavatory faucet
The lavatory faucet in my 2015 24R runs remarkably slowly. It runs so slowly that the water pump cycles off and on while the faucet is open. (Other faucets, etc, seem to run ok...)
The faucet is molded plastic, with a chrome finish. I'm thinking that I need to remove the aerator and let it run...but the aerator doesn't seem to want to budge...and I don't want to break it.
Any thoughts?
Dave
DaveJordan is offline   Reply With Quote
Old 06-30-2015, 02:29 PM   #2
TURBS's Avatar
The aerator is properly plugged with debris.
It should screw off.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-30-2015, 06:24 PM   #3
It was a bit of a battle, but I got the aerator off without breaking anything. I ended up using a pair of pliers with a non-slip rubber pad between the pliers and the plastic.
And it turned out that there was a bit of plastic (clear, thin, flexible) caught in the aerator. It works much better now.
Dave
faucet
