Old 03-26-2013, 09:39 AM   #11
GM
bclemens's Avatar
Originally Posted by Loefflerh View Post
Any idea where it is in the 24R? For both - the rear and side slide?
Behind the black abs cover with the fresh water tank
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 03-27-2013, 03:29 PM   #12
Loefflerh's Avatar
Smile
Thanks...off to search for a black abs cover
Loefflerh is offline   Reply With Quote
Old 04-06-2013, 07:29 AM   #13
Loefflerh's Avatar
I found the "brain" ! But what happens when the slide out is stuck in the open position? Is there a way to manually crank in the side and rear slide in case e.g. electric motor failure??
Hans
Old 04-06-2013, 07:35 AM   #14
Crusader's Avatar
Schwintek In-Wall Slide System (Trouble Shooting Tips) By Lippert Components. - YouTube
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 04-07-2013, 08:31 AM   #15
Loefflerh's Avatar
Crusader, thank you for that link.....I would never have found that screw! So i will have a piece of 2x4 cut to the right length with me in the coach!
I was searching for a manual crank somewhere......
Hans
Old 04-25-2013, 11:25 PM   #16
We just ordered a Solera MS yesterday. Wondering if there is a manual override for a stuck bed?
Fla Lizard is offline   Reply With Quote
Old 04-26-2013, 07:44 AM   #17
GM
bclemens's Avatar
It would sort of the work the same way as the Lippert slide (same mechanism). You need to disengage the motors to have it operate freely. If the power is off from the slide you could sloooooooowly raise it, but you'll be fighting the gear reduction in the motors.
Old 04-26-2013, 12:12 PM   #18
van_fl's Avatar
The most problems with slides that I have found are not with the controller. What I have found with mine and others is that the connectors that were instilled at the factory some have had bad crimps . Itís a time consuming task but if push, pull and shake all of the wires going into the slide controller you will find the problems with the slide sometimes working then not.
You have to do this this when operating the slide in and out.
van_fl is offline   Reply With Quote
Old 04-26-2013, 11:16 PM   #19
Thank you. Since we ordered our MS without actually getting to see an actual model I've been a little concerned about a stuck bed. Hopefully we will never have to deal with this issue.
