Old 11-26-2014, 04:57 AM   #1
'79 Bonneville
Solera 24R subwoofer
Can someone tell me where the surround sound sub-woofer speaker or speakers are installed in the 24R with the mattress option over the cab?
A picture would help if available or convenient.
bcunning is offline   Reply With Quote
Old 11-26-2014, 08:16 AM   #2
My 2013 24R with the couch has it behind the couch. F.Y.I. it hummed and I had to turn the volume control down on it.
3886john is offline   Reply With Quote
Old 11-26-2014, 08:19 AM   #3
Mikegjax's Avatar
Mine hummed also until I installed a "ground loop isolator" to the radio.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-26-2014, 09:51 AM   #4
My 24R with a table option is under the seat right behind the drivers seat.
13larry is offline   Reply With Quote
Old 11-26-2014, 10:17 AM   #5
'79 Bonneville
13larry,
is that under the front dinette seat in the base that has the sliding drawer in it?
Old 11-26-2014, 10:26 AM   #6
Yes you are correct
Old 11-26-2014, 10:30 AM   #7
Mikegjax's Avatar
Forward dinette seat, behind the drawer on my 24R. Extend the drawer out and look to the rear of the compartment with a flashlight and you ill see it.
2014 Solera 24R
USN Retired
Old 11-27-2014, 12:33 AM   #8
I have a 2015 24R. Yes it's under the forward dinette seat. To access the subwoofer, remove a few screws that's holding the wooden panel underneath the cushions. Slide the drawer out or remove the drawer so you can step into the dinette seat. The subwoofer is located far against the wall. It's held down by 2 screws. Once the screws are removed, you can adjust the settings for the subwoofer. It's a 8" powered a sub. The reason for me adjusting the settings. The gain in the subwoofer was set to zero. No matter what setting I adjusted on the stereo for the subwoofer. I was not getting any sound from the sub. That's why I went to the sub to adjust the gain. Now the stereo is sounding the way it's supposed too.
Ealbay is offline   Reply With Quote
solera
