Old 06-10-2014, 09:38 AM   #1
Solera Cable Hook-Up
My first try to hook-up my cable in our Solera to no avail. Anybody have the same issue? Thanks.
Capt Dan
2013 Solera S
Williams, AZ
CaptDan is offline   Reply With Quote
Old 06-10-2014, 10:32 AM   #2
hkreck's Avatar
Had the same problem removed the plate in the storage area found that the cable wire wasn't hooked up.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 06-10-2014, 02:03 PM   #3
2012 Solera
On our 2012 Solera "S" - hook up park cable to connector in utility compartment; IMPORTANT - turn "OFF" the antenna amp (push tiny button on back side of plate inside compartment above door so that green LED is not lit), got to menu on TV, select cable, scan for channels.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-10-2014, 11:43 PM   #4
Just arrived The Desert Eagle RV Park, Nellis AFB, Nevada. I will try your fix on the amp tomorrow-Thanks.
CaptDan
Old 06-11-2014, 06:53 AM   #5
bubbles's Avatar
CaptDan
Nellis famcamp now has cable?
Old 07-06-2014, 10:56 AM   #6
JLeising: Followed your quote above and it worked "Great!" Thanks for the info.
Dan
U.S. Navy Resort & Rec. Center
Pacific Beach, WA
Old 07-06-2014, 12:05 PM   #7
2012 Solera
Great news! Thanks for the feedback.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-14-2014, 01:24 PM   #8
Yep - we had trouble and had to turn off our antenna booster as well!
The Nutter Family
2015 Solera 24R
knutter is offline   Reply With Quote
solera
