Old 11-17-2014, 11:59 AM   #1
Solera MPG and DEF Capacity
Considering the FR Solera vs Ford Gas C class. Do you get 12-15 MPG as the sales people state? Also, I read the DEF capacity is 2gal and only last 5,000 miles. Is that true?
oregonct is offline   Reply With Quote
Old 11-17-2014, 12:14 PM   #2
Ecopco's Avatar
I regularly get 12-13 mpg on my 2015 (2014 Chassis) Solera 24R and I drive 70+ on the Interstate. Some here get 14-15 mpg with reduced speeds. I have added DEF at about 4200 and 8400 miles. Just over 2 gal each time so I think your dealer is giving you a pretty straight answer.
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 11-17-2014, 12:30 PM   #3
2012 Solera
My experience is essentially identical. 12 MPG highway (can be 11 with strong headwind); About 2k miles per gallon of DEF. After service I wait 3K miles, then add a gallon of DEF and add a gallon every 2K miles thereafter (avoid warning lights). On our Alaska trip - while we were traveling slower - saw many 14-16 mpg tanks of diesel.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 11-17-2014, 12:44 PM   #4
hkreck's Avatar
I get about 14 MPG not towing, towing takes it down to about 12. Same as the other's on the DEF.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 11-17-2014, 12:48 PM   #5
Thanks very much.
Old 11-17-2014, 03:29 PM   #6
Picked our Solera Nov 11th. So far two fillups and get 13 mpg. I'm happy with that. I picked up DEF Fluid but have no idea when to put it in. Have a thousand miles on it now.
lwalkplumb is offline   Reply With Quote
Old 11-17-2014, 03:37 PM   #7
hkreck's Avatar
The newer model Solera's have the DEF tank up under the hood next to the radiator. Very small opening for the tank you'll need a funnel.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 11-17-2014, 07:09 PM   #8
Mikegjax's Avatar
The 2.5 gallon DEF container that I get has a short hose/nozzle in the box.
Thus you don't necessarily need a funnel. The tip of the hose fits perfectly in the filler opening. A small air valve on the nozzle allows you to control the flow by holding your finger over it. I believe the DEF tank is approx 3 gallons.
MPG diesel around 14.5 not towing, 11.8 to 12.8 towing.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-17-2014, 11:45 PM   #9
GM
bclemens's Avatar
^^ What he said ^^. Used to be 7 gallons next to the door, but that took a storage compartment. So when it could move to engine compartment we did. Went to 3.2 gallons if I recall.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-18-2014, 12:01 AM   #10
We avg. 15.1, not towing, 58-62MPG, DEF 2K MPG, pretty typical
PaDawg is offline   Reply With Quote
mpg, solera
