Old 08-30-2013, 03:03 PM   #21
Hooray!!!! Good job .....
Originally Posted by Pedrodasdas View Post
OK, VOILÀ ! After untwisting all the connections, cutting all the tie-wraps and removing the black tape and foam. I AM GETTING 14 VOLTS ALL THE WAY ! BRAVO TO ME ! But , I don't know what the problem was. Probably some people at FR are playing too rough on those wires.
My step is working as it should, means it close by itself when ignition is put on. My awning can not be opened when engine is running but the slide out does (I think it is normal for a 2011)
I am now discharging my coach batteries to verify if they will get charged by the alternator.
DebbieMH is offline   Reply With Quote
Old 08-30-2013, 03:19 PM   #22
Loefflerh's Avatar
Nicely done!
one word of caution - you have to get a can of foam and foam the whole area again. Put something underneath or use your neighbors driveway - whatever drips down you will not get off again, thanks God I did it at my sons rental unit in MO!
I was told to use a 2 component foam because construction foam will not adhere - could not get it and used a 3$ can from homedepot and it works perfect.
Hans
Loefflerh is offline   Reply With Quote
Old 08-30-2013, 06:28 PM   #23
Broadway Joe's Avatar
A Piece of cardboard works wonders, and if all else fails newspaper for the overspray, drippings.
Broadway Joe is offline   Reply With Quote
Old 08-30-2013, 09:00 PM   #24
Send a message via Skype™ to Pedrodasdas
Finally put everything back in place.
Just still don't know if coach battery will charge on alternator. I hear the clicking of the relay but the readinds on the voltmeter doesn't change. Will truly see on my next trip to Old Orchard next week.
Loefflerh: I can not use the four lights to verify charging cause it is another problem I have, the four lights are always on even my my battery is completly down to 9 volts ! I'll work on that too soon.
Thanks everyone for your help.
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
Old 09-08-2013, 11:45 PM   #25
same problem
Today i noticed that my house batteries are not charging while underway. I think that is new, as i think i would have noticed it before this.
for the record (2012 solera on 2011 freightliner chassis)
1. steps auto retract when engine starts but redeploy if door is opened.
2. slide functiions with motor running (do this almost always to save on battery drain)
3. awning will not open with engine running.
scanguage usually shows 13.7 volts to the engine battery. haven't checked isolator relay for voltage when running. should i see the 13.7 from the alternator at the relay? Or is it somehow switched off if it is being used to charge the chassis battery as suggested by an earlier post?
Or is it an indication of a broken wire as OP has found?
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 09-09-2013, 12:23 AM   #26
Loefflerh's Avatar
1. that is ok
2.depends - I think somewhere in 2012 FR started to add the safety feature (slide not moving with engine running)
3. that is ok too and indicating to me you have a different problem, obviously you get power from the ignition to the circuit board.
I would measure Voltage at your house battery next. With the engine running and a fairly good engine battery the relay should engage ( you can hear it engaging) within about a minute and voltage at the battery should be around 13.7V.
Should the engine battery be low it will get charged first, and then the house battery...
Hope that helps Hans
Old 09-09-2013, 07:37 AM   #27
Originally Posted by Loefflerh View Post
1. that is ok
Agree that your ignition orange wire is fine. If still not charging, I think your problem should be in the battery control center so the BIRD or the relay itself. I'm also stuck with this problem.
I also think that charging does not occcur when engine is running at idle speed. Just made my trip to Old Orchard and coach batteries appears they have been charged whilr driving.
Old 09-15-2013, 06:31 PM   #28
I,M back from Maine and, bou-hou, Solera is still not charging on alternator.
I have power o that orange wire and a brand new Converter. Just don't know if it is the BIRD or the isolator and don't know how to check them !
Old 10-05-2013, 07:41 PM   #29
Just to close that thread:
The problem was caused by a faulty solenoid.
It probably died because that orange wire going on and off all the time.
Change the Solenoid, everything is back to normal.
Old 10-05-2013, 09:37 PM   #30
Good reference. Thank you.
2012WhiteSolera is offline   Reply With Quote
charging, solera
