Old 08-28-2013, 05:34 PM   #1
Send a message via Skype™ to Pedrodasdas
Solera not charging on engine
I am slowly getting my charging problem solved,,,,,,almost !
Got my new converter 55 amp so now, it's charging on 110 volts.
It's still not charging on alternator.
Point A: 14,21 volts from engine running
point B: 9,8 volts from coach batteries,
Point C; 0 Volts but if I trigger with a current, it will then show chassis battery current
Ignition: Shows 0,11 volts !?!?!?
Is the problem the relay or the BIRD ?
Name:	isolator relay.jpg
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
Old 08-29-2013, 09:31 PM   #2
Hum, I supposed I will have to ask somewhere else
Just to add, the relay is now very hot, normal or not ?
Old 08-30-2013, 05:50 AM   #3
Sorry, like I've posted before - I'm lucky to change a lightbulb - so I'm no help. Hopefully someone in the know can help.
DebbieMH is offline   Reply With Quote
Old 08-30-2013, 07:58 AM   #4
Loefflerh's Avatar
It sounds like my Problem when I got the coach - read my post "Battery Isolator-!2V from Ignition" maybe you got the same problem! Initially I thought too the BIRD is defective, it was the orange cable coming from the steps to the control panel supplying voltage from the ignition!
BTW can you move the slide and electric awning when the engine is running??
Loefflerh is offline   Reply With Quote
Old 08-30-2013, 08:08 AM   #5
No, no one can move either when the engine is running ....
Old 08-30-2013, 08:24 AM   #6
VinceU's Avatar
Solonoids usually heat and or vibrate when energized and the core cannot find the center. Good ones can be aligned, yours is sealed and cannot. The gas solonoid BTW can burn you on contact!
Old 08-30-2013, 09:33 AM   #7
Loefflerh's Avatar
Debbie, my question was for troubleshooting....I know you should not be able to...but like it my case with the orange cable ripped off the safety feature was disabled!
Hans
Old 08-30-2013, 10:33 AM   #8
DebbieMH: Thank you for the moral support, I need it !
VinceU: OK, I will keep my fingers and my nose away.
Loefflerh: Just went to Forest (that's my Solera's nickname, Roll Forrest Roll) Yes, with the engine runnig , the slide and awning works
I know there is a problem with the orange wire and a posted the problem last year cause my electric step would not retract and did not get an answer.
I will read your post but if you have the solution, please let me know !
Old 08-30-2013, 10:49 AM   #9
Loefflerh: Just read your post, very easy to understand for a Frenchie like me, thanks.
I will go dig in the foam and see if I can find a broken wire because,the steps were working fine when I bought Forest.
Now, can somebody confirm or infirm I should get 12 volts on that orange wire in the battery manager section (look at the low right corner on the picture on the first post), it's the orange wire market ignition.
Old 08-30-2013, 10:51 AM   #10
Loefflerh's Avatar
I am sure you have the same problem I had ....read my post. you have to crawl underneath the coach next to the steps (forward of them) and start digging the foam away till you find that orange cable there. Once you find it and reconnect it everything is working fine and the slide out will not work with the engine running!
Steps were working fine on mine too when I had that problem....and yes you should have 12V on that orange wire with the engine running (just to turn on the ignition is not enough)
Hans
charging, solera
