Old 07-06-2012, 01:45 PM   #1
Solera Parked on 10% Slope
Does anyone know if there are any issues with operating the refrigerator or generator, or other utilities when parked on a 10% slope? This is for short term use (a couple hours) only while i prep rv for trips. I know this isn't the ideal condition but I'm hoping it is ok for short term. Thanks.
sradaich is offline   Reply With Quote
Old 07-06-2012, 06:32 PM   #2
Great Horned Owl's Avatar
Depending on the direction of the slope and the make of the generator, the low oil sensor may decide there is not oil and refuse to allow the generator to run.
The fridge almost certainly will not work on that slope. Worse, you may possibly destroy the cooling DO NOT DO IT.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 07-06-2012, 07:31 PM   #3
if the level bubble is at least 1/2 in the circle it probably is ok. if it's just a couple hours better to shut fridge off.
gerrym51 is offline   Reply With Quote
Old 07-06-2012, 07:55 PM   #4
MtnGuy's Avatar
If the fridge is on the back wall, 10% slope may be OK. If it is on the side as in most motor homes, then I would cut the fridge off while on that slope. The absorption fridges that are in RVs are more susceptible to extreme tilts side to side, but not as much from front to back.
