Old 12-26-2012, 06:33 PM   #11
ilmor's Avatar
Originally Posted by emilizik View Post
I check with Hunter and the following numbers are all the same:
Model 42995/42997/42999B I just installed 42995 the same way as 42999B was installed and i am very happy as it function. After one degree loss its starts again.
emilizik
Cool! Ill get the 42995 and try it also! Glad these things aren't too expensive. Thanks for posting.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 12-26-2012, 06:48 PM   #12
ilmor's Avatar
Ordered it - $19.95 free shipping.
Old 12-26-2012, 07:21 PM   #13
Witch Doctor's Avatar
Originally Posted by ilmor View Post
I've decided to postpone this new thermostat until I get more info. I was unable to make it work using the instructions above. The Dometic thermostat is different, plus I have a heat pump which I wasn't sure how to handle. Any experts on the forum that can assist?
If you have a heat pump that subase will not work as stated earlier.......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 12-30-2012, 05:45 PM   #14
I'm confused. Doesn't Solera's AC/heater system, which is really a heat pump, and not a heater, I say that because the specs listing that came with the unit says "heat pump". So this thermostat will or won't work?
2012WhiteSolera is offline   Reply With Quote
Old 12-30-2012, 06:03 PM   #15
ilmor's Avatar
Yes, there r a few confusing statements above, however if I do get mine working ill let you know!
The Solera has a heat pump in the roof (can heat and cool),as well as the propane-powered furnace heat. The one thermostat controls both systems.
Old 12-31-2012, 07:44 AM   #16
That sub base will not work with a heat pump system, it will only work with a propane furnace and a plain old a/c not a heat pump !!!!!!
