Old 07-17-2011, 07:23 PM   #1
ilmor's Avatar
Solera Thermostat Upgrade
I don't know about the rest of you, but the thermostat in my '09 Solera is terrible. It's very difficult to get it to set and stay at a satisfactory temperature.
I've been reading a bit on the internet and I'm going to attempt the Hunter digital thermostat install. From what I can tell, this is a great improvement if it works!
I've ordered the thermostat; I'll keep you all updated.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-19-2011, 02:07 PM   #2
2018 FR3 30DS
Ilmor...which thermostat do you have in mind? I googled hunter digital thermostats and came up with several...some of which are battery powered and some are 24 volts (assuming they need separate wiring and power source??).
My Solera is 2011 but the thermostat doesn't keep room at constant temperature. It waits too long to start either cooling or heating.
NEW SUBJECT: Last week I took my mh to a machine shop and the man welded two pieces of steel (one was 3" channel and the other looked like a 1 X 3 inch hollow rectangular bar.) The 3" channel bar was about 6 inches long and the rectangular bar was 14" long. He welded the 3" bar to the end of the rectangular bar making it an L shaped configuration. He made 2 of these, one for each side. He then went under the mh and bored 2 holes in each spring hanger and 2 matching holes in the 3" bar. He attached the L shaped bracked to each spring hanger and the 14" bar is at the edge of the mh on each side. He also welded a 5/8" solid bar between the two pieces connected to each spring hanger. I can now put scissor jacks under each of the bars and it will stabilize my rig. The bars are just in front of the rear wheels. Nothing is welded to the MH/
Sorry, no pics (yet).
Slow_movin is offline   Reply With Quote
Old 07-19-2011, 05:07 PM   #3
ilmor's Avatar
Old 07-20-2011, 09:06 AM   #4
papap's Avatar
Need pictures. LOl
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 07-27-2011, 06:54 PM   #5
2018 FR3 30DS
Solera thermostat upgrade
Have you bought/installed the thermostat to replace the original? Which one did you select if you have bought one?
2011 Solera
Old 07-27-2011, 06:58 PM   #6
ilmor's Avatar
2011 Solera
I just got the thermostat in the mail. It is the same one as that described in this link;
Hunter 4299B Digital Thermostat RV Installation
I won't be able to get to this task for another 1 1/2 weeks, but I will repost here and let everyone know how it goes.
Old 08-13-2011, 07:48 PM   #7
ilmor's Avatar
I've decided to postpone this new thermostat until I get more info. I was unable to make it work using the instructions above. The Dometic thermostat is different, plus I have a heat pump which I wasn't sure how to handle. Any experts on the forum that can assist?
Old 12-15-2012, 05:21 AM   #8
ilmor's Avatar
Bump - anyone have any updates on this issue?
Old 12-26-2012, 02:57 PM   #9
I check with Hunter and the following numbers are all the same:
Model 42995/42997/42999B I just installed 42995 the same way as 42999B was installed and i am very happy as it function. After one degree loss its starts again.
emilizik
emilizik is offline   Reply With Quote
Old 12-26-2012, 03:17 PM   #10
Witch Doctor's Avatar
The model you showed is not a heatpump stat it will not work with a heat pump only propane..........
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
