Old 06-08-2015, 07:51 AM   #11
jeff64's Avatar
Originally Posted by devilsquid View Post
Good morning all, I have a problem that I don't think has been mentioned here before. My 2013 Solera won't start but the starter motor does turn very slowly. I had just pulled it forward out of our RV carport (normal start up and no check lights). I shut the engine off to get things ready to wash the beast, wanted to move a little closer to the water source...no go. The chassis battery went flat after our last trip in Feb. I have had the chassis battery on charger for the last 3 days and it's indicating that the battery is fully charged and is on the maintenance float charging cycle. I tried to use a jump starter pack which made zero difference in the sound of the starter. Anyone have a clue to what might be going on. Any help, suggestions or opinions would be greatly appreciated. Thank you.
Going by what I have learned through various industrial and automotive courses... rule of thumb in electrical diagnosis is" start at one end of the circuit or the other, not in the middle, but, from the easiest most accessable place. In your case from the battery and it's terminals including body and chassis grounds. I assume the starter would be more difficult to access Don't change any parts, even cheap ones unless your testing says its bad. That's the difference between a technician and a hack parts changer!
Get a volt/ohmmeter and learn ( by google) if necessary how to test batteries, resistance and voltage drop.
Therin lies your clue!
Old 06-16-2015, 11:12 PM   #12
Devilsquid, did you ever find the fix for your issue?
Old 06-22-2015, 09:09 AM   #13
devilsquid's Avatar
Still Kickin, I never did find a fix for this problem but what did happen is that, that particular gremlin moved on. I had my wife try to start the engine while I measured the voltage drop on the chassis battery. We cranked it for a bit longer than I had previously and she started up. I still had the battery checked out and it tested WNL. We took our scheduled trip to Idaho and never had a problem starting up...go figure.
devilsquid is offline   Reply With Quote
Old 06-22-2015, 09:15 AM   #14
mike.t's Avatar
Still sounds like a bad winding in the starter.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
solera
