Old 05-10-2015, 07:47 PM   #1
Send a message via Skype™ to Pedrodasdas
Something is growing under my floor !
Hi All,
Presently in Indiana, on my way home to Quebec from Texas.
Yesterday we found a little bump in the floor. In short, there is something trying to sneak out through the linoleum and, before it tears it, I,m trying to find out what it can be.
It looks like a bolt head but I can not see anything undercarriage. I tough it was related to the slide out bars but, no, the bump is more to the rear.
Today, it is sticking out a little bit more.
You can see on the picture where it is, 19 inches from the drawer and 20 inches from the step.
Any idea ? My only option is to cut the lino before it tears.
Pierrôt and Sylvie D'Astous, Solera 2011
38 on 50 states, 9 on 10 provinces.
Pedrodasdas is offline   Reply With Quote
Old 05-10-2015, 10:41 PM   #2
Just a hunch. Check to see if the protrusion is in line with the slide supports, or frame, possibly the corresponding nut has become loose on the underside. Just guessing.
Old 05-10-2015, 10:46 PM   #3
asquared's Avatar
Is it hard or soft? My linoleum developed a bubble but it turned out to be a result of what they call a floating floor. The bubble comes and goes.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-11-2015, 09:34 AM   #4
The bump is about the size of a big round bubble gum, very hard.
No, it is not in line with the slide out supports.
No, it is not moving when I press on it like it would if it was a loose bolt.
Twillight zone !
Old 05-11-2015, 11:59 AM   #5
LANShark42's Avatar
First of all, Welcome to Indiana! You're in the home state of some great RV manufacturers/sales/service companies. If you can't get it fixed here, you won't be able to get it fixed anywhere!
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 05-11-2015, 05:20 PM   #6
News ! Got a magnet and it is sticking so.....looks like a bolt head to me, will have to investigate again under.
I am out of Indiana now, cross Illinois and now in OHIO !
Very nice weather here !
Old 05-12-2015, 08:02 AM   #7
Ask B Clemens if he can shoot you a picture (in production) of the S model, in the same orientation you posted, before the lino is installed. That might help. Sure sounds like a nut loosened allowing the bolt head to work its way up. Sure would hate to cut the lino if its just a simple draw down of a bolt.
Old 05-12-2015, 08:37 AM   #8
Thank you Still Kickin but I already know it is a bolt head for sure. My problem is to locate the nut under to rescrew it.
Old 07-01-2015, 10:10 AM   #9
What ever happen to that bolt head?
Old 07-01-2015, 11:06 AM   #10
Oups, you are right, I forgot the follow-up.
The bump was a screw holding the plywood floor to the frame. Looks like a big huge metal screw with a Phillips head.
The only way to get it was to cut the linoleum, screw it back in place and place a bit of glue so it will not unscrew again, then reglue carefully the vinyl floor in place.
I have no idea how and why that screw unscrewed !
