Old 06-21-2011, 10:19 AM   #1
2018 FR3 30DS
Step Stabilizer
Does anyone use a stabilizer under their step? And this brings the question: does anyone use stabilizers under the Solera and if so, what kind?
I have tried using screw top jack stands with little or no success. I put them under each end of the reciever hitch and it helped a little but they usually work loose and have to be adjusted. Do you think the rear bumper is strong enough to place the stands under each end? I use commercial blocks under the tires for leveling.
Thanks for your thoughts....
Slow_movin is offline   Reply With Quote
