Old 04-06-2015, 07:56 PM   #1
Tail light condensation
Washed the Solera today and noticed soap suds in tail light and condensation in the other tail light. I removed the two screws holding it on and noticed that there is not any gasket or seal to keep water out. Has anyone figured a fix for this?
2015 Solera 24S
tominfl is offline   Reply With Quote
Old 04-06-2015, 09:42 PM   #2
Oklahoma Proud
MillerTime's Avatar
Pull the light out and drill an 1/8" Hole in the bottom close to the lense. This will allow water to drain out and air in. (Just did this on a vehicle last week)
It is imposible to completely seal one and it last. Thats why oem lights are vented. Most likely upfitters like Forest river use aftermarket lamps as cost are much cheaper than oe.
Old 04-06-2015, 11:48 PM   #3
Phinias's Avatar
Where can I obtain OEM lights?
Phinias is offline   Reply With Quote
Old 04-07-2015, 09:53 AM   #4
Sounds like a warranty issue. Best bet is to show dealer the issue, have them order new light buckets, and then bring it back(after there in) for the change out.
Old 04-07-2015, 10:10 AM   #5
Oklahoma Proud
MillerTime's Avatar
If they are a style like the vans use or something like that, you could get from Mb, ford or who ever they are styled from. If they are the rectangular type with 2 or 3 light in it, there probably isn't an actual "oem". You would just have to shop around, or If possible, warranty them like Still kickin mentioned.
Old 04-07-2015, 10:13 AM   #6
I ran a bead of clear silicone around the gap between the lenses ... let it set up about 1/2 hour and added another very thin bead before attaching the lens. No issues since.
MiataHoarder is offline   Reply With Quote
Old 04-07-2015, 04:18 PM   #7
Thanks for the ideas, I haven't had much luck with warranty issues. I guess since there are no seals maybe they expect them to leak. I think my time will be better spent trying to seal them myself.
2015 Solera 24S
light
