Old 06-06-2014, 07:24 PM   #21
hkreck's Avatar
OK, the 2014's are wider than the pervious models that's probably why you didn't have a problem with the twist on.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 06-06-2014, 07:26 PM   #22
Needs Help
Originally Posted by hkreck View Post
I was measuring my 24S and I came up short for the twist on version. Not really sure it's worth the cost anyway.
What did it measure? Mine was about 9 3/8". I had to make some changes but it's going to work.
Living_The_Dream is offline   Reply With Quote
Old 06-06-2014, 08:48 PM   #23
hkreck's Avatar
My measured 8" from the tabs on the discharge to the side wall.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 06-06-2014, 09:15 PM   #24
Needs Help
Ok I was unaware the 2014 was wider. Glad I got one. I will have mine working tomorrow.
Anyone know if leaving the plate that covers the manual screw on the end of the motor is a problem?
I put tape over the hole to keep dust and grime out. I have not run it yet.
Old 06-07-2014, 06:55 AM   #25
Needs Help
I meant to say leaving the plate off the end. I'm assuming it's just a dust cover.
Old 06-08-2014, 11:15 AM   #26
Mine is at 10-1/4" so I guess I got lucky.
I would try it with the dust cover off. If it fits, then try to find a permanent solution for covering the hole.
mphair is offline   Reply With Quote
Old 06-08-2014, 08:13 PM   #27
Needs Help
I was at CW today and they had an older version mounted for display. The screw is exposed. I suspect the newer model is covered to better protect it from weather.
Your lucky to have that extra space. I just hope I don't have to get at the screw. I always plan to make sure it's spinning before I dump the black tank. One day I may drill a hole to the outside for access to the screw.
Old 06-25-2014, 10:02 PM   #28
Needs Help
I have used mine a few times. It works nice. My only complaint is the hose doesn't drain easily when done emptying the tanks. I have to walk it several times to finally get the bulk of the water out. Mine pump is mounted with the output on top so it doesn't gravity drain completely either. No room to
2014 Forest River Solera 24S
Old 04-04-2015, 03:04 PM   #29
Has anyone installed a sewage macerator in the 24r model. The sewage bay doesn't seem to be as large as on the 24s model for some reason. I'm thinking I won't be able to permanently mount anything in such a small bay. Any thoughts?
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
