Old 02-26-2014, 03:07 PM   #21
Mikegjax's Avatar
I use a silicone spray treatment on the seals that prevent them from sticking. Also prolongs the life of the seal. You can find it a Walmart and most auto parts stores.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 03-02-2014, 07:33 AM   #22
Originally Posted by Fr125 View Post
Jleising, I can only hope that we don't have major problems with the slide like you did. I will not follow through with the purchase unless this slide works 100%.
So, what did you decide? Did you get it or pass?
DebbieMH is offline   Reply With Quote
Old 03-02-2014, 10:07 AM   #23
Taylorgso's Avatar
The slide will stop when motors are out of sync. There is a routine for resyncing them - dealer should be able to show the procedure. They get out of sync for various reasons. You may also find instructions in Swintek user manual. And DO use the rubber lubricant but don't let it get on the slide gears/rails!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
2012, solera
