Old 10-12-2014, 07:50 PM   #1
TOAD - 2014 Honda Fit
Hello all, I am considering getting a vehicle to tow behind our 2014 Solera. Has anyone towed a Honda Fit. (Automatic) and if so we're there any hurdles in the process? I am presently searching for the owners manual to confirm that it is ok. Also, what were the peripherals used to connect the toad to the RV. Thanks in advance....
Roger64 is offline   Reply With Quote
Old 10-12-2014, 08:40 PM   #2
Plain Old Member
We towed a 2012 Honda fit. It can be towed 4 down, and it was shown towards the back of the manual I believe. I think it has a speed limit of 65. You can see our previous set up in my photo album. We used the Falcon All Terrain tow bar, which was simple. I installed the base plate, light wiring and diodes myself to save a bunch of money, and it was really quite simple. There are some YouTube videos on that specific car that are helpful.
We absolutely loved that car. It was a lot roomier than it appeared from the outside. We had 2 carseats in the rear, and plenty of room up front, plus plenty of room for groceries or whatever in the hatchback. I also used the car for work when not behind motorhome, as it got 40 mph on average. Just a great car.
I think this would be a good fit for a Solera.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 10-12-2014, 11:41 PM   #3
We are new owners of a 2015 24r and tow a 2013 Honda Fit with automatic transmission. It tows quite easily, hardly know it's there. We like the light weight of the Fit to mate with our Solera.
jngspencer is offline   Reply With Quote
Old 10-12-2014, 11:57 PM   #4
What type of tow bar are you using and did you install a braking system. I understand for most states anything under 3000lbs towed is not required a braking system.
Old 10-12-2014, 11:58 PM   #5
Thanks for the info. YouTube helped a lot!
Old 10-13-2014, 11:02 AM   #6
We used Roadmaster products. Camping World did the install of the base plate, wiring, Falcon all terrain tow bar and Invisibrake braking system.
In California the weight limit is 1500 lbs for a braking system but all states are different.
Old 10-13-2014, 02:00 PM   #7
HONDAMAN174's Avatar
Is it a 2013 fit or 2015? Honda did not make a 2014. The 2015's are not towable.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 10-13-2014, 02:04 PM   #8
It is a 2013 Fit
Old 10-13-2014, 02:07 PM   #9
In Canada they (Honda) have advertised a 2014 model but we are looking for either a 2013 or 2014.
2014, toad
