Toad Brake and Turn Signal Wiring
I plan to tow a 2013 Honda Fit behind my 2013 Solera. All the mechanical towing bits are in place, but I cannot get the brake lights and turn signals to function.
After considerable troubleshooting, I think that the output voltage from the seven pin connector on the Solera is insufficient to power the incandescent lamps on the Fit. The black wire on the connector (constant 12V) works fine, and I see a change in voltage on the appropriate turn and brake signal wires, but it doesn't seem sufficient to power the Fit's lamps.
I understand that the Solera lights are LEDs. Does anyone know what the output voltage from the Solera should be? Could it be the difference between the power required for the LED lamps on the Solera vs the incandescent lamps on the Fit?
Thanks in advance for any help or insight you can provide.
