Old 01-14-2016, 05:54 PM   #1
Phil
Towing Honda FIT
Anyone using a roadmaster tow bar to tow a 2015 manual Honda FIT? Getting ready to have gear installed. What drop receiver will be needed? Anyone using the Invisibrake system?
Phil Kuebler is offline   Reply With Quote
Old 01-14-2016, 08:19 PM   #2
HONDAMAN174's Avatar
Try this thread:
Tow Gear for the 2015 Honda Fit
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-14-2016, 09:43 PM   #3
Drivestregis
Drivestregis's Avatar
I tow a 2015 Honda Fit EX. I use Roadmaster and Invisibrake. Very satisfied with rig.
Drivestregis
2014 SOLERA S
Retired Cajun
2015 Honda Fit Toad
Drivestregis is offline   Reply With Quote
Old 01-14-2016, 11:52 PM   #4
I tow a 2013 Fit Automatic with Roadmaster and Invisibrake with a 2015 Solera. Works excellent. I had Camping World install it.
jngspencer is offline   Reply With Quote
Old 01-14-2016, 11:53 PM   #5
I did not need a drop receiver
Old 01-15-2016, 08:33 AM   #6
I tow a 2016 Honda HR-V, the Fit's slightly bigger brother (both made on the same assembly line...) I use a Blue Ox base plate and tow bar with (I think) a four inch drop receiver. I'm using the SMI Stay-N-Play Duo braking system.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 01-15-2016, 10:28 AM   #7
A manual transmission HRV, I presume? I don't think the new variable transmission models are flat-towable. That's part of the reason I found a 2014 CRV to tow.
2016 Sunseeker MBS 2400R + Diesel Gen
2014 Honda CRV
Blue Ox Flat Tow Equipment
SMI Stay-In-Play Brake Controller
ericlakin is offline   Reply With Quote
Old 01-16-2016, 09:45 AM   #8
Yup, the CVT models aren't towable. (One depressing consideration is that you can only get the roof rack rails with the top-of-the-line model...which only comes with the CVT. Ah well.)
Dave
2015 Solera 24R
Old 01-16-2016, 05:21 PM   #9
Phil
Thanks for replies, Talked to camping World and ordered parts (Roadmaster + Invisibrake). Should be set up before our next trip in March.
Old 02-26-2016, 11:03 AM   #10
Phil
Well, I did have Camping World install the Roadmaster tow bar and Invisibrake, and they did a great job. Took longer than expected since the first Invisibrake they received was not working and company had to send a new one, which they did in short order. Seems to work great, but have 2 questions.
1), The FIT has a push button starter, and we left the key in the car since I was afraid taking it with me to the RV would turn off accessories and lock the wheels. Does anyone know if you can take the key fob out of the car so it can be locked while traveling, or do you have to keep it in the car while towing?
2) They did not use a drop down receiver and the tow bar is angled down a few inches to the car (no more than 2-3"). I noticed the front wheels look a bit depressed compared to the back (could be due to the weight of the stone guard installed). Do I need a drop down receiver to get the tow bar absolutely level with the car brackets?
Thanks in advance for any info
towing
